Was this through Carista?I have this on mine too, perfect for that situation
As I can’t see that option on mine, I am also currently set to Australia as a region if that makes any difference
I did the same via VCDSI have this on mine too, perfect for that situation
I've had this done on mine and its great for a bit of stealth charging of my leisure battery.There’s an option to have no DRLs when parking brake is on, will achieve the same as you want and they will come on as soon as you remove handbrake
With VCDS, I don't have Carista so don't know about that. Mine is also set to Australia, I think most of us are, it's the way you get the large Mp/h speedoWas this through Carista?
Oh thanks for that hopefully Carista can add it as a update in the future!With VCDS, I don't have Carista so don't know about that. Mine is also set to Australia, I think most of us are, it's the way you get the large Mp/h speedo
Why ?Would need to remember to return the setting back to normal when you present the vehicle for an MoT.
Thats annoying, as I don't have VCDS.Yes, but the MoT and the requirements that the vehicle is expected to meet in regard to it's lighting, are carried out on a static vehicle. Unless you could convince the tester to check the lights with the handbrake off.
Mines 2017. Now I'm smiling again.If memory serves me correct though, DRLs being operational is only a requirement on vehicles registered after 1st March 2018. It was one of the recent changes I believe.
Is this on Carista? I can’t seem to find itYes there is an option to turn off DRL when parking brake is active
I used VCDS to do it
