DRLs and H7 upgrade
New read is:
B8A4393A0A6B349193284D747E999E7CCFA0690F60C869CC320400230800
In the coding there are quite a few non-factory features related to lights:
BYTE-BIT
12 -1 DRL adjustable now active (presumably in dash menu - however, doesn't work on T6)
13 - 1 Now Parking light function is not active
13 - 4 Now "1" - however function unknown to me
21 - 7 Now "1" - however function unknown to me
23 - 2 Foglights as DRL :unsure:
23 - 3 Low beam as DRL :unsure:
BYTE-BIT
What can I say, @mmi
You are a star.
23 2 and 3 was indeed the issue… which could only be solved with long coding as the OBDeleven menu is counter-intuitive.
All working now, glad I didn’t have to take the bumper off again to double check the bulb fittings!!!!
Still no joy…
Can I check… obdeleven
1) I swapped the setting to have both dipped and full beam on. Worked fine
then
2) there is a setting to change the light setup from H4 to 7E/7F double headlights / h7… do I choose this?
Hi, can you remember what setting you went with in the end, h4 or h7 setting, I’m having the same drl issue
