Dynavin T6.1 fit
I’m really tempted to get this unit since seems a good deal but I’m always cautious when things look too good to be true.
I have T6 but looks like it’s the same unit with different compatibility kits.
Are you still happy with the system? Have you encountered any issue since apart from the DAB?
I just want to use CarPlay anyways and I don’t need anything else.
Hi
I got mine for the same reason - to be able to use CarPlay. The CarPlay works seamlessly - connects wirelessly and my unit 100% of the time I am driving is using Waze, Apple Music, Spotify, BBC Sounds and Podcasts through CarPlay.
The only annoying bits for me are it sometimes takes 1-2 minutes for the CarPlay to connect when I turn the van on and my DAB problem you read about (but that may not be the unit - it could be down to the aerial).
Thanks for the quick response.
Did you get the flex and then paid the extra after the 31 day trial? I could get the unit for €299 and then add €99 to use the CarPlay.
I read that the brightness is not as strong as other units. Have you had any issues with the screen not being bright enough?
I have had no issues with brightness on the screen, it has always been perfectly reasonable. When I purchased CarPlay was included in the price, but the price was significantly higher than those you quote. My model is D8-333 - I dont know if the D9 is a new unit or if it is just as software upgrade.
