EcoWorthy
Anyone fitted an Eco-Worthy LiFePO4 100Ah battery under the drivers seat in a T6.1 T32? If so, have you got any pics on how you did it.
I fitted a renogy 100ah lithium battery underneath the drivers seat, battery laying on its side terminals forward, split charge relay in front, had to fabricate a bracket for the battery to sit on but quite straight forward with plenty of room, bit hard to get pics now because my seat is refitted.
Not an EcoWorthy, T32 or the driver’s seat but will hopefully give you an idea. It’s a Fogstar Drift 105ah which is the same size (or very, very close - think it’s the same case) under a T28 single passenger seat.
I've got one in a battery box.
Hi @ginkster, thanks for the pic, do you by any chance have a wiring diagram? I want to include a DC-DC charger, smart shunt and a battery protect. I think I will get all Victron so that I can control/monitor them through the app. I am not doing 240V hook up or solar so I think it should be fairly straight forward.
I don’t have a diagram to hand I’m afraid but Nohma.com are a good source.
It’s pretty simple - you will need the following:
Short cable from Starter battery (SB) to a 60a midi fuse then cable to the DC-DC pos input there is a grommet behind the SB into the cabin.
Neg from DC-DC to chassis ground point (there are ones under the seats) or a neg busbar.
DC-DC pos output to a pos busbar. Fuse this cable close to the busbar.
From leisure battery (LB) pos a short cable to a midi fuse (size tbc) then cable to an isolator switch (not mandatory but recommended) then cable to pos busbar (the one mentioned above).
LB neg short cable to shunt input then cable from shunt output to chassis ground (or a neg busbar if using one). Nothing else must be connected LB side of the shunt otherwise you will get false readings. You need a fused pos cable from shunt to LB pos (supplied with shunt). You get another thin cable that can be added to the shunt aux and connected to the DC-DC input to also get SB voltage in the app.
You don’t need a battery protect with lifepo4 as this role is done by the battery BMS.
Any power sources then take the pos feed from the busbar with a suitable size fuse at the busbar end to protect the cable. Sources can either take the neg from the neg busbar or local chassis point, whichever is easier/shorter.
That is about it. Cable/fuse size can be worked out from the diagram below.
If you draw up your plan (inc length of cable runs) we can check it and help advise on fuse/cable sizes.
Depending on your use case I’d really recommend solar. It is a game changer when combined with a lithium battery. I find I very rarely use the DC-DC and haven’t even bothered fitting the mains charger as solar is sufficient for my use.
Meant to say, I would recommend also fitting an Ablemail AMT12-2 that will trickle charge your SB from your LB. It’s great if you are camping as opening doors, van interior lights coming on and central locking etc all drain the SB fairly rapidly. Ideal the AMT works best with solar keeping the LB topped up (or mains charger on EHU) but even without it’s best to sacrifice a little LB power to ensure your van will start.
Also, for the DC-DC there are 3 models to load on at. The 18A Orion isolated - cheapest and lowest powered (about 5 hours from empty to full). The 30A Orion non-isolated - mid priced, runs a little warm but fits fine under the seat (about 3 hours flat to full). The Orion XS (50A but selectable to lower amps) - newest, most expensive but smaller, cooler and faster charge (would recommend setting to 30A so similar to above charge wise). I have the 30A and it’s fine. All depends on your use case and budget really.
Personally I like to use the app for my Fogstar battery as I can connect to it when the van is on the drive from the kitchen inside the house. Helps me know if I need to do a quick charge.
If you really want to keep on top of things that's the best 'cheap' way to go. But if you are happy with a simple voltage readout eco can't be beaten for the money.
DC House 200Ah battery on offer on Amazon today for £306
I have this battery. Works perfectly, capacity as advertised. Install a Bluetooth shunt with it to monitor charge stats.
Personally I'd stick with brand names and a bt BMS.
You get what you pay for....
Safety with lithium battery's should always be you first concern.
Watch the teardown videos on YouTube too see the dodgy stuff they do with cheap battery's.
Confusing isn’t it!
however,
Most van owners on here will be supplying their battery via a DC-DC charger with a temp probe, so it’s a moot point in those cases.
If there's no low temperature protection on the battery BMS you'd need to have it set on the DC-DC, MPPT, and 240v EHU charger, so a BMS low temp protection is far better and easier to implement.
Most chargers do not have low temp charge protection and a lithium profile... Just a select few.
