I’m curious as to why.Any modifications to the emissions systems would be a MOT failure. It’s not advisable to remove the EGR without removing the DPF also.
Well, I take issue with some of the shite dark side write on their site, so personally wouldnt believe a word they say.@huw169 Disabling the EGR can cause the DPF to block, the EGR Valve operation is a prerequisite for DPF Regeneration. I was told this by Darkside, I looked in to having the EGR blanked after nearly 3 years of issues.
Did they describe how to drive it "properly"?Hi - quick update on the EGR issue. With 12k on an 18 plate T28, the EGR/NOX warning (P0401) was showing. I took the van to VW Wakefield for a full service in the hope they'd show some compassion and fix the EGR issue. Delighted to say that after they spoke to VW, they did a flush and it's now working fine and says it will continue to do so as long as it's 'driven properly'. If you have a similar issue, it's worth getting the local dealer to to speak to VW and see if they can fix as a courtesy even if out of warranty. Low milage and just out of warranty definitely helped but it sets a precedent.
Please drive your new van down a motorway like it's stolen at least once a week to avoid breaking down and not having the van for a week when you may need it most.
Are you sure those driving criteria weren't about the DPF, rather than the EGR?I was told that 12k was acceptable for the EGR to fail if it hadn't been driven more than 50mph for short period (less than 15 mins) and the tank was less than 25% full. Apparently the EGR only works (or is effective) on longer journeys at speed. Seems to be the party line from the dealerships, but VW obviously accept that there is a design fault with the device. Most of my journeys will be longer trips so I'm hoping that the EGR will keep itself clean, but the dealership was making a massive assumption about how the previous owner had driven the van over its first 3 years. Thankfully, VW have on this occasion, done the right thing.
..that's what the dealership told me. DPF wasn't even mentioned.Are you sure those driving criteria weren't about the DPF, rather than the EGR?
My van having the same issue. Bought new and first flush out at 7k and now going back to Preston Van Centre next week for the same fault - P0401 at 12k milesVan spec: MY18 204tdi DSG, covered 43k.
During the warranty period the EGR has been flushed 7 times, approximately every 6k miles. The last flush was done in January 2020. Each time the fault code was P0401 EGR insufficient flow.
The warranty expired in February and the van is now showing the same fault. I’ve booked it into the van centre later this month and told them about my dissatisfaction with the product and reminded them that they had 7 chances to fix this. I’ve got a case ongoing with VWVC customer care but I haven’t got any faith in them.
The van is on finance with VWFS, does anyone know whether they would put some pressure on VW to get this sorted? I’m fed up with this now and it’s taking the shine off my ownership.
I’d also like to know whether the EGR and cooler is now and updated part.
Answers on a postcard![]()
Egr valve only tends to operate whilst cruisingI’ve had no problems with the DPF on mine (touch wood!) .
I don’t know the pattern of the opening of the EGR so difficult to say which driving style is worse, although a cold diesel tends to be more sooty than a warm one, so lots of cold starts would seem to be problematic.
I tended to get the engine emissions light when I was on the motorway with the cruise on, but that could just be a coincidence.
Not sure that I agree with that, carbon will be deposited from unburnt fuel or/and oil if there is insufficient gas flow to carry it through the system.commented that the only way carbon can build up is with the presence of oil.
Carbon deposits should normally be removed from the cooler by means of the exhaust gas flow. The fact that carbon is building up and not being able to be removed by the exhaust gas flow is suggesting that something else is preventing this. The only other substance that can get into this area is oil that has come into contact with the combustion process.Not sure that I agree with that, carbon will be deposited from unburnt fuel or/and oil if there is insufficient gas flow to carry it through the system.
Technically Diesel is an oil.
