Could try Mr. Muscle.
The lads who run veg oil have problems with build ups and Mr. Muscle is used a lot.
How did you remove the EGR operation from the ECU? I'm presuming you've had it done by a third party through a new calibration. The angry red faced man at Barnoldswick that does a lot of Transporter recalibrations states these engines need the EGR operational for an effective DPF regeneration so I'm interested in a different tuners approach to this.I had problems with the EGR but no performance loss or what so ever .. i only get fault codes from the EGR but nothing crazy.
After driving the T6 for 3 years got tired of it and blanked off the EGR and removed it from the ECU its still does its job DPF Regeneration.
Hi Mooncat - didn’t remove the inlet manifold just the EGR@Kevin Fleming - how coked up was the inlet manifold when you did the EGR?
Sorry for slow reply but after trying to contact him I've failed. So, don't know which chemicals he used.Mark do you know what chemicals he was using by any chance? I know about the oven cleaner and that but would want something better that’s going to blast it clean
How did u blank it was it mapped out of ecuI had problems with the EGR but no performance loss or what so ever .. i only get fault codes from the EGR but nothing crazy.
It’s about £530 for the part at VW. I paid about £1100 all in with new front and rear pipe, fitted.Got same issue here. 2017 102 model 50k miles. Recently light came on with same code. Anyone know the cost of a new egr? Or has anyone had experience with any carbon cleaner service? Don't facing attempting to clean it myself
Yep. Wynns valve cleaner / turbo cleaners are the same product rebounded for thr most part. They are just hydrocarbons and parafins in a spray can.Anyone ever tried that Wynn's valve cleaner ?
A bit late to this thread. How did it run in the end after the clean up.
