EGR Valve fault!
Autospark
Looking for some help with a 2014 T6 sometimes goes into limp mode and EGR fault code pops up it clears straight away for three to four weeks have scaned it and here is list, it has a different head unit fitted hence some codes in cluster
Monday,15,July,2024,16:58:12:02134
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.5.0.0 (x64)
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZGH092759 License Plate:
Address 01: Engine Labels: 04L-907-309-V2.clb
Control Module Part Number: 04L 906 056 KM HW: 04L 907 445
Component and/or Version: R4 2.0l TDI H02 6186
Software Coding: 0019401C430401090000
Work Shop Code: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KM 004013 (VN75)
ROD: EV_ECM20TDI03004L906056JT.rod
VCID: 020C00449507478655-8056
1 Fault Found:
15560 - EGR Sensor 1
P046C 00 [01100100] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 115501 km
Date: 2096.01.18
Time: 16:18:47
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 52 °C
Intake air temperature: 20 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 12.609 V
Unlearning counter according OBD: 40
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Exhaust recirc.valve 1 bank 1: posit.feedback - Specified value: 4.85 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: -4.40 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Offset closed: 0.00 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Raw voltage: 2.456 V
EGR vacuum regulator solenoid valve 1 bank 1: res. Cooling mode stop: 2.281 V
EGR vacuum regulator solenoid valve 1 bank 1: res. Bypass operation stop: 2.560 V
Readiness: 0 0 0 0 1
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 18 19 25 37 5F 61 69 0B
VIN: WV2ZZZ7HZGH092759 Mileage: 115500km-71768miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: Sporadic communication error 1000
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KM HW: 04L 907 445
Component: R4 2.0l TDI H02 6186
Revision: 23002001
Shop #: WSC 02737 790 50316
VINID: 9E60AAAAA1D8A976002421C52405A052EF
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 115501 km
Date: 2096.01.18
Time: 16:18:47
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 40106000002150
Coding: 307E4098256B84800C7C027BA48B21D3790000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3F8AC9B0A675EA6E7A-806A
No fault code found.
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 16121513470542
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF474B4E1FF236631-802A
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E0 907 040 L HW: 7E0 907 040 L
Component: ClimatronicT5 H03 0509
Revision: 00001K03
Coding: 0000000103
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis_VN75.rod
VCID: 2C508EFC470361F6CF-8078
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 C HW: 7E5 907 049 C
Component: Heckbedienung H11 0303
Serial number: BHB-0011101160015155
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revision: B9080001 Serial number: 0771 012161431
Coding: A0F4793A0A613493922849646C2B8DD48D20698960E44960320400BF0800
Shop #: WSC 02748 790 12345
VCID: 68D832EC9B7B8DD6EB-803C
Subsystem 1 - Part No SW: 7E0 959 801 K HW: 7E0 959 801 K Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serial number: KU0KU007011660077498
Coding: 1400B0
Subsystem 2 - Part No SW: 7E0 959 802 K HW: 7E0 959 802 K Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8654
Serial number: KU0KU008121553423481
Coding: 0400A0
Subsystem 3 - Part No: 7E1 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 5 - Part No: 7E1 951 171
Coding: 000000
Subsystem 6 - Part No SW: 2H0 959 442 HW: 2H0 959 442
Component: E221__MFL-DC1 H02 0103
Serial number: 39170002053560107307
Coding: A40000
1 Fault Found:
50990 - Unknown Error Code
Unknown - 014 -
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 66844 km
Time Indication: 0
Date: 2020.09.13
Time: 12:50:41
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 E HW: 7E0 959 655 E
Component: VW10Airbag00C 008 0016
Revision: -------- Serial number: 003PJ0012WYU Dataset Number: 7E0003V____ 0745
Coding: 000000000000000000000000000000003043
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3878A2AC835BDD56BB-806C
Crash sensor for side airbag: driver side:
Serial number: 3495ZRB405R3K8QGIG8U
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3505ZRB40613K8QGJP21
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 L HW: 7E0 920 970 L
Component: KOMBI H05 1008
Serial number: 00000000000000
Coding: 770F010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
VCID: 336295809A3D3E0E8E-8066
1 Fault Found:
13654544 - Databus
U1121 00 [00001001] - Missing Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 125
Mileage: 115501 km
Date: 2024.07.15
Time: 16:06:34
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 273 A HW: 7E0 963 273
Component: STH-T5GP2 002 0009
Coding: 4101
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 2B528DE0420D66CEC6-807E
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revision: B9080001
Coding: 042305
3 Faults Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 165
Mileage: 115191 km
Time Indication: 0
Date: 2018.11.26
Time: 09:04:20
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 66844 km
Time Indication: 0
Date: 2020.09.13
Time: 12:50:40
03158 - Control Module for Information Electronics 1 (J794)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 66844 km
Time Indication: 0
Date: 2020.09.13
Time: 12:50:40
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 1008
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADC48E48D77BFC6FD-803E
Address 37: Navigation
Cannot be reached
Address 5F: Information Electr.
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 030B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serial number: 52342848211261219630
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
VCID: 30689A8C632B0516F3-8064
End-------------------------(Elapsed Time: 03:17)--------------------------
Have you seen this?
Elsewhere on the internet, there are various posts that VW recommend just to clear it if it's the only engine management fault code. Another source has had a similar issue (where both sensor 1 and 2 were at fault) and a new EGR cleared the problem. You could probably spend ages chasing it
