Is it worth taking a set of fuel injection quantity values as well? mg/sAnother a relatively easy check before teardown would be to make yet another log by using the following measurement values:
IDE00021 Engine RPMIDE00351 Main injection: start of activationIDE00352 Main injection: duration of activationIDE00589 Fuel pressureIDE09327 Cylinder 1 bank 1 internal momentIDE09328 Cylinder 2 bank 1 internal momentIDE09329 Cylinder 3 bank 1 internal momentIDE09330 Cylinder 4 bank 1 internal momentIDE12085 Fuel injection time deviation: cylinder 1IDE12086 Fuel injection time deviation: cylinder 2IDE12087 Fuel injection time deviation: cylinder 3IDE12088 Fuel injection time deviation: cylinder 4Tick Group UDS requests - by 7 (IMPORTANT!!!)Preferably start logging before cranking.
Just a view from different angle to see if/where the imbalance is. Neither cylinder internal moments should not deviate much.
Here was another mystery - though resolved - by replacing camshaft module.
Won’t start. No fault codes
Nice, if i disconnect camshaft sensor, engine will start so i quess camshaft module needs to be replaced. I couldn do it correctly. I have hex+can cable andwhile trying to "Tick "Group UDS requests" - by 7" it says i need new interface. So i got only 1 time logging whivh didnt show anything...www.t6forum.com
It's hard to say from a distance but it seems the original failure was caused by a split EGR cooler. I would take that back off and check that the EGR to inlet manifold are clear. I had a Qashqai in where the garage said DMF had failed. I found the EGR was wrecked and the gearbox/engine mount knackered so the EGR caused a mis-fire/rough low rpm running and was exaggerated by the knackered mounts. All solved for £300 instead of the £1400 Nissan wanted.Thanks for taking the time to produce the graph!
Certainly helps me understand it, where would you advise I go from here?
Do you think it's an injectior issue, or is there an underlying mechanical issue?
I guess HPFP is ok as readings are ok.
Knackered rings/valves that seal up when warm?
A bent rod wouldnt disappear when warm?
Or do I just drive it until it throws a rod or really shows me what the problem is
I would agree - the pressure builds up quickly and obviously the pressure regulation works as the pressure is stable.I guess HPFP is ok as readings are ok.
Hard to say - I would be think the issue is something more traditional - possibly even a moved cam lobe? Wondering if an audio clip could be captured of rough idling?Do you think it's an injectior issue, or is there an underlying mechanical issue?
Based purely on the gathered data (blockmap data, below) I would say these are not the prime suspects.- Check timing of timing belt and camshaft position sensor.
IDE00182 | Camshaft adaptation intake bank 1: phase position | 0.3 | ° |
I'm not sure if that would be any different - I guess it would correlate strongly with injection duration. At the moment I'm lacking reference data on that.Is it worth taking a set of fuel injection quantity values as well? mg/s
So it was running factory map on all the above measurements?Had Map removed - No different.
So was it the charge air cooler or the EGR cooler that was replaced, or both? (from your first post)First issue was it started to use coolant, I swapped a known good charge cooler to eliminate that, Max to min in around 100 miles, So took it to VW specialist in MK about 10 miles away, on route it started misfiring at low rpm, EGR/Cooler changed for £1.4k….
It might be worth making a temporary blanking of the EGR and seeing how it runs then. The 3 EGR problems I dealt with all shared the common problem that they leaked exhaust gas all the time and allowed it in the inlet manifold. EGR is not necessary at idle or low loads as its there to introduce inert gasses into the inlet to dampen the firing temperature below 1200degC. This effect reduces the amount of NOx formed. This only happens under engine load thus is not needed at low load or idle. If it does happen at idle or low loads , then it causes misfire or rough/lumpy engine behaviour.So was it the charge air cooler or the EGR cooler that was replaced, or both? (from your first post)
Both, Changed charge cooler and no change, Changed EGR and coolant loss stopped immediately.So was it the charge air cooler or the EGR cooler that was replaced, or both? (from your first post)
Hey man, seen your post, had the same issues with my van so everything you did I did the opposite. I managed to find a VW master tech which diagnosed it to be the G247 fuel pressure Sensor valve on the side of the fuel rail once fitted with fuel additive next day, perfect. Hope this helpsGood shout, I can try that tomorrow I will report back,
I have open and closed EGR via VCDS and it appears to function but I will block it off and see how the van reacts.
Thank you all for your help - I will report back!
Adam
Cool. I ordered mine from TPS which was in stock and they said it’s a common part they sell and the part has been updated due to its common fault Ooh that is something new to try, Let me see if I can get one ordered. Thanks!
NAM600 - Blocking the EGR made no difference to the lumpy idle, if anything it was worse. it's just so strange how it runs perfectly once up to temperature.
Your vans fuel pressure is stable according to post #30, renewing the pressure regulator valve or pressure sensor doing seem like the obvious route for diagnostics.Ooh that is something new to try, Let me see if I can get one ordered. Thanks!
