Electric problems after driving through water
Where are you measuring that 12v from?
If it's an accurate 12.0v then that's around 50% charged and the point where charging is advised.
I doubt battery voltage alone is your root cause, but low charge, or a tired battery that dips low on starting, can cause issues.
It stated it when I plugged in the carista, my fluke voltage tester showed 12v exact so not too worried, was just chasing all options really as it’s a pain not having my van as it’s my only vehicle
Hi all
Sorry to bother you again, I’ve just pulled my van forward and it now has a coolant fault, checked the reservoir and it is below minimum although the vans not moved and is parked on a downward slope but I’ve also noticed orange on the passenger side of the radiator, I’m thinking this is a leak rather than spillage or over flow, what do you think?
