Help peeps. Adblue warning came on suddenly when wife driving. No countdown warnings. Went and bought Adblue and topped up. Reset but no start. VW assist came and told her it was an ‘Adblue micro switch fault’ but didn’t give her a report. The van was recovered from Wales to a local indie in Manchester. Of course it started and ran fine, 6500 miles on adblu range. Only fault on scan was fuel pressure rail that’s been there for a while. They said drive it and see what happens. Roll on 2 weeks. Van been sat on drive with little use so thought I’d take it for a run. EML came on straight away so I scanned it. Could someone clever have a look and advise me please?
TIA Mike23864
TIA Mike23864
Code:
Monday,12,September,2022,08:07:53:11618
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZHX012845 License Plate: AM11KEG
Mileage: 73470km-45652mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZHX012845 Mileage: 73470km-45652miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KG HW: 04L 907 445
Component: R4 2.0l TDI H02 6168
Revision: 23002001
Coding: 00254014432501090000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KG 004013
ROD: EV_ECM20TDI03004L906056KE_004.rod
VCID: 7CA1FC499669B1CBFB9-8028
VINID: 9E606AAAA1D8A98A0004220414663BE1CC
3 Faults Found:
27307 - Fuel Pressure Regulator Valve (N276)
P2294 00 [032] - Open Circuit
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 73364 km
Date: 2066.01.05
Time: 13:26:58
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 31 ∞C
Intake air temperature: 27 ∞C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.007 V
Unlearning counter according OBD: 33
Rail pressure regulation: status: Control operation: ignition on
HPV current demand coming from the IMV control: 100 mA
HPV current demand coming from the HPV control: 100 mA
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
P_L_Rail_pres_sample_cnts-counts: 104.899 counts
Fuel high pressure sensor: nominal value: 200.0 bar
Fuel high pressure sensor: actual value: 0.0 bar
Mean injection quantity: 0 mg/stroke
Battery voltage: 12.007 V
Fuel temperature sensor 1: B1: raw value: 25.2 ∞C
Coolant temperature at engine outlet: calculated: 31.0 ∞C
Terminal 15 status: On
Setpoint generation interior torque: 0.0 Nm
31155 - Reductant
P20E8 00 [096] - Pressure too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 73409 km
Date: 2066.01.18
Time: 08:35:28
Engine RPM: 2130.25 /min
Vehicle speed: 61 km/h
Coolant temperature: 86 ∞C
Intake air temperature: 17 ∞C
Voltage terminal 30: 14.703 V
Unlearning counter according OBD: 40
Outside temperature sensor 1: B1: raw value: 16.0 ∞C
Reducing agent pump module relative press.: calculated: 2259 mbar
Reducing agent fill level sensor: act. value: 128 mm
Sensor for reducing agent tank temperature: temperature: 16.5 ∞C
Reducing agent system pressurization release conditions-Engine running: Condition not met
Reducing agent system pressurization release conditions-Press. enabled: Condition not met
Reducing agent system pressurization release conditions-Heat. strategy: enable: Condition not met
Reducing agent system pressurization release conditions-Depressurized min. time below limit: Condition not met
Reducing agent system pressurization release conditions-Catalyst temp.reached: Condition not met
Reducing agent system pressurization release conditions-Release due to jammed valve needle: Condition not met
Reducing agent system pressurization release conditions-Rinse function finished: Condition not met
Reducing agent system pressurization release conditions-Initial filling completed: Condition not met
Reducing agent system pressurization release conditions-Release via inducement: Condition not met
Reducing agent system pressurization release conditions: 255
31160 - Control Circuit for Reductant Pump 1
P208B 00 [168] - Implausible Signal
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 73438 km
Date: 2066.01.21
Time: 17:39:01
Engine RPM: 1293.75 /min
Normed load value: 96.5 %
Vehicle speed: 25 km/h
Coolant temperature: 65 ∞C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.000 V
Outside temperature sensor 1: B1: raw value: 20.0 ∞C
Reducing agent pump module relative press.: calculated: 577 mbar
Sensor for reducing agent tank temperature: temperature: 20.0 ∞C
Readiness: N/A
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 046 J HW: 0BH 927 711 G
Component: DSG DQ500-7F H11 5302
Revision: 00H11V01 CVN: 5459F477
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW37.rod
VCID: 3D27314DCDF378C38C7-8068
No fault code found.
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 42646000000181
Coding: 517E4098256384808A7D027AA48721E6790000
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB4B45C7FF6AD39EB-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 01081613470328
Coding: 01
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F6418075A3DBD5D-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AK HW: 7E0 907 047 AK
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 73B3D775BB37FEB3AA3-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 270160598
Coding: E0A4303A0A212031002809742C2B8C540F80708F60444D60320400220800
Shop #: WSC 35110 377 08192
VCID: 2A0D0A112CFDFF7BD95-807E
Subsystem 1 - Part No SW: 7E0 959 801 P HW: 7E0 959 801 P Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 0653
Serial number: KU0KU022091662666732
Coding: 1400B0
Subsystem 2 - Part No SW: 7E0 959 802 P HW: 7E0 959 802 P Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 0653
Serial number: KU0KU023091662677452
Coding: 0400A0
Subsystem 3 - Part No SW: 2H0 959 442 HW: 2H0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H02 0103
Serial number: 39210000380880071105
Coding: A40000
1 Fault Found:
03442 - Return Message Closing Status of Rear Lid
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 205
Mileage: 73372 km
Time Indication: 0
Date: 2017.01.09
Time: 16:03:37
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 T HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0212
Revision: -------- Serial number: 32961625001469
Coding: 10810A
ASAM Dataset: EV_VW75XParkAssis4K 001013
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 43D347B5AB170E33FA3-8016
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag021 H08 0018
Revision: -------- Serial number: 003V3002BZDC
Coding: 000000000000000000000000000000003231
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A2D3A51DCDD4FFBA95-806E
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1104
Serial number: 00000000000000
Coding: 450B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
1 Fault Found:
13654544 - Databus
U1121 00 [009] - Missing Message
[Steuerger‰t f¸r Telefon keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 205
Mileage: 73364 km
Date: 2022.08.15
Time: 13:27:04
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042305
VCID: 6889B019F2710D6B0F1-803C
1 Fault Found:
03158 - Control Module for Information Electronics 1 (J794)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 198
Mileage: 73364 km
Time Indication: 0
Date: 2017.01.05
Time: 13:25:44
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1104
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DCA11ECFD3F7B195-803E
Address 5F: Information Electr.
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 030B1A73
Shop #: WSC 59760 004 1048576
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75410903001609260396
End----------(Elapsed Time: 01:19, VBatt start/end: 12.1V/12.1V)-----------
