Friend of mine experienced this
Code:
38703 - Engine Coolant Bypass Valve 1
P26B1 00 [00100000] - Stuck Closed
[Engine Coolant Bypass Valve "A" Stuck Closed]
38704 - Engine Coolant Bypass Valve 1
P26AB 00 [10101100] - Stuck Open
[Engine Coolant Bypass Valve "A" Stuck/Open]
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
on his T6.1
Code:
Engine (J623-DNAA)
SW: 05L 906 023 D
HW: 05L 907 309 F
R4 2.0l TDI H80 1351
so I helped him to replace infamous coolant bypass valve.
03N 906 249 G -> O3N 906 249 K
These faults were caused by the failure of internal sealing and effectively coolant ingress into electrical section.
Fingers crossed for the revised version to last for good.
