Solid red light on the door means there's a fault in the central locking system....
You'll probably find the turn signals don't flash either when you try and lock / set alarm due to door open being sensed...
The door is causing issues... based on mmi's post, it may not be connected to the 'leaving home' lights problem, but its hard to say for sure...
if you can get a VCDS scan it would help show up any other problems or provide more detail for troubleshooting.
