Hi guys, can see a few threads on here regarding the sensor at fault. I’ve had three fault codes pop up after a turbo replacement, P2031, P2032, P2458 (last of which I’m not worried about as should jump into regen when sorted). I’ve replacement the egt sensor with an NGK one and am still getting the same issue.
I’m not 100% sure where to go from here, have I made a mistake in not buying an OEM part and should I try that before doing anything else?
Also, if anyone know, should that egt sensor give some sort of a resistance reading when using a multimeter on it?
Thanks in advance for any help!
