Don't forget @cgtmiles....the size of the seal is crucial. This is exactly what I used......16mm x 15mm Self Adhesive Neoprene 'Eared' Rubber 'D' Section Per Metre from Car BuilderOk, many thanks for going to the effort, great photos.
So this is exactly where mine are now apart from I have mine following the crease up by the wheel arch. I’m pretty sure the issue is at the other side of the door but I’ll try moving (or maybe just removing) the seal where it kicks up and see if that helps
cheers
This is one of those minor modifications that seems to be causing no end of confusion with all sorts of weird and wonderful ways of placing it.....I've said it before (several times), if you place it the same as a caravelle and it's the right profile....job done! I've used this on two vans....it's been on this van 3 years.....no problems at all......it's never come unstuck and I've never had to slam the doors.....I just don't understand some of the misleading "guidance" on here. Some people seem to be going bl**dy mad with this stuff! I Can't blame you for being confused.......I Hope that clears it up mate?
![Thumbs Up :thumbsup: :thumbsup:](/styles/default/xenforo/smilies/thumbsup.png)
