I think the flea bay ones have reduced road noise a bit on mine but doesnt sound like a golf by any means. Might by some more 3m tape for my THQ seals and try cutting air vents inI’ve started experimenting with the excess and I’ve put it in the mid point (directly below the rubber stopper at the top of the door) most of the way down the door and it seems ok so it may be the bottom of the door that’s the issue. I haven’t been able to play much as the drivers door is right up against the neighbours flower bed.
The smaller seal I bought from fleabay is ok but on its own it still doesn’t sound as good as the passenger side.
Luckily I get in and out the passenger driver to avoid the flower bed so might just dukes of hazard the drivers side
I tried this already and you can close the door ok but it doesn’t help the sound so a bit pointless.Tried mine a few more mm inboard and it did help very very slightly, but door still bounces back and sits out slightly. Prob need to try it a good inch further in then.
Probably too late tho, I ripped it off in Morrisons car park on Saturday evening and it's still in the footwell.
I have just bought the travelin lite seals as I noticed they had the same shape as this. Haven’t had a chance to fit yeah but will report back.Here is a close-up of OEM factory installed seal (right door, top corner). Seems to have thinner walls than aftermarket ones. Interestingly it's also asymmetrical - thicker wall "inside".
Fitted mine a few wks ago.... wow just wow night and day from how it was!I have just bought the travelin lite seals as I noticed they had the same shape as this. Haven’t had a chance to fit yeah but will report back.
Interestingly, on the site they show the seals in different positions in each photo on the ad
So far I have tried:Fitted mine a few wks ago.... wow just wow night and day from how it was!
It does close like a golf and gone is that horrid tinny twang !
Best £15 mod there is I’d say
Blimey.. aside from being skint, you’ll be the U.K. subject matter expert by the end of it!So far I have tried:
eBay seals ~£12
THQ seals ~£18
Smaller eBay seal ~£12
And now TL seal ~£17
I am the expert on zero success in getting the bloody thing to sound good or shut!Blimey.. aside from being skint, you’ll be the U.K. subject matter expert by the end of it!
Oh if only I had seen this before !
Follow this vid and I promise you'll have doors that close like a golf and sound like a golfOh if only I had seen this before !
NopeFollow this vid and I promise you'll have doors that close like a golf and sound like a golf
