But if you want versatility raise it.
Van = utility vehicle.
Ours was very handy on a recent Coastguard shout (a friend had borrowed the Outback); loads of clearance, good grip with the 4wd. The T6 is also much better protected underneath than the T5.1 we used to have.
Thanks - I hadn't seen that document before. On the basis of the document there would seem to be no difference between the 2 (CXFA/CXHA) 150PS variants, i.e. only 1 mention of both which appears on the same chart. I know I'm clutching at straws but I was hoping to see something that says there is a difference somewhere and can be used as the basis of further categorising the problems a few people have reported with the 150 DSG, i.e. are they happening on the CXFA, CXHA variant or both.
How do you know which engine you have?????Excellent. Looks promising
! I saw in another thread that yours is 150ps+DSG, which should imply engine type of CXFA. Could you please check/report for us instantaneous consumption on your MFD when engine is idling (turn off Auto Start/Stop before you stop) after some driving (10 mins+), engine hot (90C), DSG at P, turning off lights, A/C, blower, etc. MFD should report it as liters/hour as soon the vehicle is standing. Thanks.
Sticker below steering wheel and/or in front of your manual.How do you know which engine you have?????
Hi mine has a CXFA engineIs your engine a CXFA or CXHA and does anyone know what the difference is?? Was there a 150 with CXGA??
Took Sandy for a drive this am. 15 miles through town and back round the bypass. When cold 35 mpg. Soon as warmed up never dropped below 40 mpg even round town. When I got back did as you said blue motion and other electrics off MFD just said ----------- so put it to add mpg. Left for 10 mins on drive running add mpg 45.7.Excellent. Looks promising
Thanks, that’s a good piece of information. Today even I saw nice 49.5 mpg after my daily 20 mile run, but for still unknown reason mine will fall on becoming Friday down to about 28-30 mpg. Well, the real number is about 9% worse thanks to optimistic MFD.
I have recorded my runs quite some time with VCDS, and I can see a strange repeating pattern in consumption doing my regular daily home-work-home runs. The cycle is about 250 km’s – so from a regen to next regen. After a regen the consumption will fall down to 28-30 mpg, and then gradually it steps up to 55 mpg till next regen. And starts the cycle over… after 200 km's from regen it will back to wonderful 50+ mpg for 2-3 days. Quite funny—a kind of!![]()
Actually what I tried to ask was if you could change your MFD to display instantaneous consumption for the reaading. It should read liters/hour after a few seconds when standing.
The reason why I’m asking is that with “good vans" it stays at 0,5 liters/hour, but mine has never shown below 0.7 liters/hour. Any numbers from 140ps EU5 variants, please?
Even when standing still?? Mine changes from liters/100km to liters/hour when I stop and stand still, and back to liters/100km when moving again.On uk vans instant consumption is in mpg, European vans are l/hr
I've found my trip computer is very close to the calculation of actual fuel used, within 1.5mpg! Generally get around 33mpg in general use and up to 42mpg (both true mpg) on longer journeys. My old hightop LWB used to teeter around 25-26 and never broke 30, so I'm pretty happy with what I'm getting now![]()
