My OEM bolts went in/on no problem with Navis Twin 5, they seem a lot more substantial than the 17 bolts that came with them.
I have to apologise for an error.A lot of aftermarket wheels, including Navis, are supplied with replacement bolts because the bolt seat is not the same as OEM wheels.
OEM VW wheels use radius seat bolts, most aftermarket wheels use 60 degree tapered seat bolts. The two should never be mixed and matched. If using the wrong ones you only have a tiny percentage of the seat actually in contact with the wheel.
I have seen bolts undo themselves almost completely and wheels close to falling off when the incorrect bolt has been used. I would be getting those OEM bolts out and putting the supplied ones in as soon as possible.
I’ve just checked with Navis HQ and they inform me that Navis wheels are all radius seat, so OEM bolts will be fine.
Sorry for any confusion.
My statement was correct for most aftermarket alloy wheels, but worth checking with the supplier or manufacturer when ordering to be sure.
