There's always more than one way to skin a cat!
I would not do what I did. I am pretty certain that the Sargent has over protection circuitry incompatible with the voltages/currents that occur in the AGM bulk charging phase. I got around this for the LB by throttling back the Victron to 7amps when on EHU. I have solar but did not wire that through the Sargent and I removed to 20amp fuse for the Main Battery as I think the Sargent was the root cause of issues I had with that AGM battery when I first got the Van.@dcpen43 thanks for your posts which I've been following with intetest. This looks like a great solution to get a decent charger to the Leisure Battery. I'm thinking of taking the same route as I'm sure the Sargent charger is not the best option for keeping my LB charged on EHU.
Did you ever manage to sort out the issue with the error when switching over to charge the Starter Battery?
Is there any anything you would do differently or any improvements?
good solution. I see the EC328 can charge AGM but not a cost effective upgradeFollowing up on earlier posts, I ended up putting the victron behind the cabinets and the 12v supply (via a changeover switch) to both the leisure and van battery under the drivers seat. Picked up the van battery from the DC-DC charger and the leisure directly. Works well
Only comment would be that step 3 and 4 remain dependent on your Sargent unit. To keep it simple you could just wire your victron +12v supply under driver seat.Thanks guys ... current plan is:
1) Remove Durite split charge and replace with Victron DC-DC charger (fitted under drivers seat next to AGM LB
2) Remove Sargent charger PSU (or bypass - taking @dcpen43 advice not to hook into Sargent spade connectors) and use Victron IP 22
3) Power Victron IP22 from Sargent - ideally rewiring the Sargent 'big red switch' to turn on power to Victron
4) Wire Victron IP22 output (+ve) to existing Sargent double (brown/blue cables) out to LB to save having to rewire this short run.
Does this sound feasible/correct ... any further advice would be useful.
I'm pretty sure the Durite split charge and Sargent PSU are killing my AGM battery.
Didn’t you take an MCB feed for your Victron @Salty Spuds? I was thinking of doing step 3 myselfOnly comment would be that step 3 and 4 remain dependent on your Sargent unit. To keep it simple you could just wire your victron +12v supply under driver seat.
Not meDidn’t you take an MCB feed for your Victron @Salty Spuds? I was thinking of doing step 3 myself
Whoops it was @Stay FrostyNot me
Did the mod to remove the Sargent from the Charging path but kept the Big Red Button as the charging switch. It feels like you are doing something when that light comes onWhoops it was @Stay Frosty
several months on with experience of reaching into the wardrobe to flick the ac rocker switch, i finally went your way @Stay Frosty and took a feed from the MCB in the Sargent and moved the red switch to a more accessible position as part of a fridge swap out.@Stay Frosty ?
I fed my Victron IP22 from one of the spare MCBs in the Sargent using some 2.5mm2 3 core blue flex behind the cabinets to a single 13A skt at the position shown in the picture earlier in the thread.![]()
if it ain't broke.....I’m haven’t needed to change the charger yet as haven’t needed to upgrade batteries, I’m guessing it will be soon though as it’s over 3 years old now but anyway, I’ve never switched that switch, always left on and with the standard setup it hasn’t caused an issue (that we’ve found!)
