Hi, did anyone get to the bottom of this in the end? I'm at the stage of making the fuel connection on my 2019 T6 Shuttle and deciding to use which of:-Hi, Would love to know if the T-piece on the return works also. Just about to drop the tank and start the fitting of my Webasto air top 2000 stc. It certainly would make life a bit easier if the T-piece worked ?
Yes, I like the sound of that! The less cutting the better! Thx oldiebutgoodie for your help.All you need do is take the fuel connection off the current pump, connect that to one side of the tee and connect the other side of the tee back to the current pump. No need to complicate matters by cutting fuel lines.
