Thanks pal, shall attempt the same.I followed Richards advice - rubber Kombi floor, 12mm ply and some Karndean LVT. Worked a treat.
Dragging this thread back up again, but I think @j4ckal, @Ads_Essex and @Garny999 have convinced me to go with leaving the Kombi rubber floor in and laying 12mm ply on top, in preparation for Cali rails in the future. The question is, did you cut the ply floor yourself or buy it, and is it 1, 2 or 3 pieces? (This is for a SWB).Rightly or wrongly I bonded (sikaflex) these sections of ply onto the van floor in the kombi/load ring cutouts in the mat. Using the sikaflex to make up the difference in height I could adjust them so they sat just underflush of the load mat to allow for some compression in it.
I then screwed (possibly bonded too I seem to remeber to prevent squeaks) the one piece ply floor to these.
Seemed to work well enough. Near side rail aluminium trim was a little 'tight' to get it to clip in though and had to relieve some of the ply to create a slightly bigger gap around the rail/clips.
The standard OEM scissor jack is useless on a T6, have a search on the forum, a hydraulic jack is a far safer option.What are everyones thoughts on the Jack/toolkit that slots into the rear of these seats? Do any of you cali seat/bed owners have one? They tidy up the back of the seat a bit.
You maybe able to fit the bottle jack in the space, plus you still need the other tools to change a wheel. Given that the wheel bolt torque is quite high at 180Nm you might want to carry a 6 sided socket, 4” extension, sliding T bar and an extension tube. It’s a far better option than the pressed steel wrench VW provide - less chance of damaging the locking bolts.Ah I see, fair enough. Would be good to make use of this space somehow.
Fantastic job done there! Well doneGreat thread, managed to do the whole job from the info in here with help from my cousin fitting the rails.
Lovely job, looks very neat. Is that made with metal?
@j4ckal Just checking your earlier photo, can you please confirm that there are 6 square headed rail securing bolts / rail?
I was doing some work on my rails and I’ve found some square holes in the rails with no bolts, it was professionally converted by a reputable company.
I know that some converters bond and bolt but I can’t think of a good reason not to install all the bolts possible.
Does any body have the full parts diagram for the Cali rail system?
