Fixing ceiling panel
gabjam
Hi all, very new to this and need a bit of advice!
Bought a 2016 T6 last week and the seller assured us he had fixed all the little problems with it. Turns out, he hadn't fixed any of them. One of the lesser problems is the ceiling panel above the main compartment - it's hanging off with a load of glue/sealant between the panel and the insulation. The insulation looks to be silver and glossy, which is why I think it hasn't stuck. The panel also flexes so if its held up against the ceiling it then 'pings' back. There's also a little foam cube between the panel and the ceiling that appears to have been pulled off as well.
How would I go about fastening this back in place? Evidently the sealant they used didn't work! Any help appreciated - we're totally new to this.
The front part of that panel should be held in place by the plastic trim in the picture. Is this a converted panel van? If the van has had a bulk head removed then the original roof panel would be too short
Brill thanks, so this could be a replacement panel job then? It was an old panel van - was a standard tradie van before conversion.
This "new, high-quality conversion" has already cost plenty in repairs/dodgy electrics as it is so that's more good news if it needs a new panel :cautious:
What @jimc91 said, your van would have had a bulkhead originally so the roof panel is designed to be held up by that. Best way to fix it is to source a panel from a van without a bulkhead and fit that in place of what you have. The correct panel will be held in place by the plastic retaining strip that's holding the roof lining in place.
Or get some 3.6 mm ply and use the old one as a template but just make it a bit longer, you only need a jig saw, then cover with something; carpet or headline material
Perfect thank you, I'll have a look around see if I can get hold of one!
that's a good shout actually, probably more cost effective!
mine had a metal plate there to fix rear roof lining on as it was lower than cab ceiling, had those sponge blocks also.
What did you use to fit the panel back up with please? Is there anything alternative to the plastic clips? I’m looking for a black industrial kind of look or gold. Any suggestions please?
I used clips from Harrison’s I think, they are like the original ones but slightly longer
When I converted my last van from panel to kombi , I glued a strip of thin hardboard about 3 cm thick overlapping end of original panel . This then tucks under the plastic trim between the two panels .
Probably not explained that very well .....
Cheap and looks fine , lasted fine .
I have the same problem, been looking on here since 7am - finally found a solution. Thanks
Are those plastic strips necessary ? The one at the front (by cab) I could keep - but I am looking to replace the ceiling in the rear and ideally would like it to run straight through from front to back without these.
thanks
Harrison trim advised me to extend my current roof panel, instead of making another.
As above. I glued another peice of 3mm ply ontop of the existing one to bridge the gap and carpet lined the lot.
Fits and looks great.
