P
Phil_G
Guest
For interests sake, could someone reveal whats actually happening behind the scenes when a new battery is 'adapted' please (ie in tech detail)?
Ta
Phil
Ta
Phil
The battery monitor has in is program a number of profiles to match the different battery types and when a new battery is added the adaption process tells the battery monitor what battery type and capacity has been installed so it selects the correct profile to follow as it measure use and controls the charging accordingly.For interests sake, could someone reveal whats actually happening behind the scenes when a new battery is 'adapted' please (ie in tech detail)?
Ta
Phil
Its quite simple if you have vcds just an adaption channel, lets the van know a new battery has been fitted and resets the charging regime/parameters so you dont end up removing a flat battery and installing a fully charged one that the van thinks is flat
Hi Pauly
without wanting to sound too stupid.... what is VCDS..?
So I tried the -ve to -ve and got enough power to unlock the doors, but not to start? Seems odd and I now have a coil light lit on the warning lights. All dashboard lights flicker, but not enough to star up.
Really helpful links, thanks very much. I like the idea of a wired in trickle charger.that will be a poor connection causing volt drop,
either bad jumper cables or corroded clamps on cable join.
either way . . .
fully charge the starter battery from the mains over night or as long as it takes to fully charge with a decent smart charger.
And NO charging the leisure battery wouldn't reverse charge the starter (some DC-DC chargers have a reverse charge, but its only small current and normally via a solar setup)
Most people have moved over to portable jump-packs instead of jump cables. (see below)
also look at fitting a battery monitor so you can see what's going on and when the battery needs a charge..
more info:
