@Drive Wayne was there any specific reason for buying the seat base Roamer 230Ah rather than the seat base 230Ah Fogstar?Are there any deals going on the Roamer 230Ah SB3 Matt? Great company to deal with and it certainly fits under there...
Roamers aftercare has been excellent, both on the phone and by email, I can't comment on the Fogstar experience, other than they have a hand in my vape batteries. OK, I may be guilty of being a bit snobbish, but I will use Roamer again in my next creation! I still wouldn't buy a Skoda, I'm just old fashioned that way. The Roamer app is good too, the whole set up to me is worth a couple of hundred notes extra, makes me feel all warm inside!@Drive Wayne was there any specific reason for buying the seat base Roamer 230Ah rather than the seat base 230Ah Fogstar?
Looking at specs, the Fogstar seems better with internal heating & on/off button & £200 cheaper?
Did you have any issues with the non heating part of the Roamer, during the cold snap we've just had?Roamers aftercare has been excellent, both on the phone and by email, I can't comment on the Fogstar experience, other than they have a hand in my vape batteries. OK, I may be guilty of being a bit snobbish, but I will use Roamer again in my next creation! I still wouldn't buy a Skoda, I'm just old fashioned that way. The Roamer app is good too, the whole set up to me is worth a couple of hundred notes extra, makes me feel all warm inside!
It worked as intended and at 0 degrees it stops accepting charge, no problems pulling power from it though. Battery heating is certainly a 'good to have' if you're going to freezing places. My Mrs won't do camping in freezing! Roamer have another range of batteries for freezing temperatures. I won't be needing one of those!Did you have any issues with the non heating part of the Roamer, during the cold snap we've just had?
I emailed Roamer re this and they suggested it wasn't needed or necessary. Spoke to Fogstar at the NEC show and they suggested it was good to have, to enable charging at low temp.
Discharge at low temps are the same for both.
Choices, choices...
Yes with a Roamer, or your money back Sir!But still the question remains unanswered....... fits with a RIB swivel??
Fogstar @ £800Can I justify £500 more for the Roamer though? Seems steep for essentially the same thing
Not any more there isn'tThere's an ex-display fogstar drift here for £650, it's got the smallest of marks on it. That's £110 cheaper than anywhere else I've seen.
[Clearance] Fogstar Drift 12V 105Ah (CLR034)
All of our clearance products have been tested prior to despatch. These items may include different packaging, minor cosmetic flaws or slight changes to the product specification. Either way, this is a great opportunity to grab yourself a bargain.www.fogstar.co.uk
Can't knock it for £650! What inverter?Not any more there isn't
