just found more info about those fridges i listed above.
looks liker they branded JOYTUTUS
Smarter Shopping, Better Living! Aliexpress.com
www.aliexpress.com
Specifications
50L -Item Size: 654X345X527 mm -Frost Zone Size: 32 x 39 x 27 cm -Chill Space Size: 13 x 23 x 27 cm -Item Weight: 17.8 kg -Cooling System: Compressor Cooling -Cooling Range: +10℃ to -22℃ -Wattage:60W -Input Voltage: DC12V/24V/220V 40L -Item Size: 654 X 345 X 442 mm -Frost Zone Size: 322L x 270W x 305H mm -Chill Space Size: 125L x 270W x 144H mm -Item Weight: 17 kg -Cooling System: Compressor Cooling -Cooling Range: +10℃ to -20℃ -Wattage:45W -Input Voltage: DC12V/24V/220V 32L -Item Size: 654 X 345 X 377 mm Frost Zone Size::322L x 270W x 240H mm Chill Space Size: 125L x 270W x 79Hmm=2.6L -Item Weight: 16.3KG -Cooling System: Compressor Cooling -Cooling Range: +10℃ to -20℃ -Wattage:45W -Input Voltage: DC12V/24V/220
Features:
【50L Large Capacity】Can put 13 x 750ml red wine; with sorting basket, have cool and freeze area, dual use,perfect fit for long journey. 【60W Low-energy,Electricity Saving】Equal to the car navigation consumption 【Power Off Memory Function】Built-in memory chip,recover the work mode when you use it next time 【Intelligence Temperature-controlled】German Converter technique,Stop cooling when the preset temperature is reached,Last over 8 hours after turn off the cooler 【Car Batteries Protection】Build-in ECO, check the voltage of the battery,cut off automatically in low-power 【Work Stable】Even in 30° tilt situation,keep working without any problem 【Intelligent Touch Screen】Comes with LCD display, Touch Screen, USB Connector;Touch sensitive, accurately control from +10℃ to -22℃ 【PP Material】Well Insulated,Safe and Non-poisonous,Not easy to corrosion,Anti-shock 【Dual Charging Methods】 can be pluged in domestic and outdoor(AC 100V-240V,DC 12V-24V) 【Dual Working Mode】HL-COOL Mode and Economical Mode optional 【Insulation Layer Inner Box with German Micro cellular Foam Technique】High density environmentally friendly PU material,insulate longer time 【Food Grade Liner】 Painted aluminum alloy of food grade. Compared with the plastic inside, the cooling speed is more than 2 times faster. 【Effectively Keep Cool】Lasting preservation over 20 hours;Experimental Test:Under circumstance temperature of 25℃-30 ℃, from lowest temperature back to 0℃ need about 24 hours with a fulfilled water.
Special Features:
Fast Cooling, Energy Saving: No ice needed, range from -4℉ to 50℉. It only needs 16 mins from 77℉ to 32℉ with an aluminum alloy chamber. The portable freezer has 2 modes: ECO and MAX.60W rated power in MAX mode, which means 1 kWh can be used for one day. You can store vegetables, fruits, frozen meat, cheese, and ice cream. Good Sleeping, Safe Driving: With 45dB low noise when it is running, you can get a cozy sleep after long-distance tiring driving and stays focus on the road. With battery protection function, it does not affect the normal start of the car. 50L Capacity with 2 Separated Area: With a 10L-refrigerated area and 40L- freezing area, the 50L truck refrigerator can store the food that you need for a week. Without worrying about eating fast food, you can save money and enjoy the cold drinks on the road. Car refrigerator for drinks is perfect for truck drivers, RVs, campsites, boats, camping, fishing, road trips. Dimensions: 25*15*23 Inches. LED Display Control: The travel fridge for car has the digital thermostat control, accurately mastered every 1 °C. Built-in LED light, more convenient to take things. The built-in basket and the divider can be removed for easy storage of food. The lid of the cooler fridge for car can be used as a table and you can place the cup on the cupholder. Car and Home Use: DC power cord and AC power cord included make it can be used in car and home.Ideal for semi-truck, Van, RV.
Package Include:
1 x User Manual 1 x 50L Car Refrigerator 1 x Heavy Duty Kraft Carto 1 x Cigarette Lighter Connector 1 x Wall Adapter
Operation:
1. Press (On/Off) key for 3 seconds to turn on/standby the refrigerator. 2. Touch the(+ or -) key to adjust the temperature. 3. Press the (+ or -) key for a long time. The preset temperature is linearly adjusted with a speed of 2°C. During the adjustment, the number does not flicker. 4. Within 3 seconds after the operation panel has not detected any key operation, the temperature display will stop flashing, exit the temperature setting, and save the currently set temperature.
Tips:
Consult the customer service about the material of cartons before purchasing a fridge. As we all know,iron is high heat conductivity metal, which will leading to poor cooling and heat preservation effect.Especially in summer, the temperature of the car trunk is up to 70℃, iron car fridge isn't a good choice. Besides, the iron painting process easy to lose paint, get corrosion and rust often, not pit impact, not durable.
Note:
1. Make sure that the power voltage connected to the car refrigerator is correct at any time (parameter labels have car refrigerator verification voltage parameters. 2. Do not pour the liquid directly into the car refrigerator. It is forbidden to transform refrigerators privately to avoid danger. 3. Refrigerator should not be exposed to the rain or the sun directly. 4. After the power on, the temperature of the side and the middle will be about 3 degrees. 5. The refrigerator will turn off after the car is off and you can plug it in to a socket that has power. 6. JoyTutus offer one year warranty and lifetime friendly customer service for the car refrigerator, if you have any questions please feel free to contact us
