Does that amazon part include 1 or 2 lamps?
it was for a pair of bulbs
Ordered!it was for a pair of bulbs
Let us know how you get on with these please any light upgrades always helpfullhttps://www.amazon.co.uk/gp/product/B01LCN5XD2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
just ordered these for the reverse lights, hope they are as successful on the fog light bulbs![]()
Very useful indeed thanks for this!Fog light upgrade; (Click on thumbnails for larger image)
Turn the steering full lock and hold the steering wheel as you turn off the engine, remove the key and gently allow the steering lock to engage to hold it.
Remove the plastic cover to gain access to the lamp holder.
Lever out the cover from the slot at the bottom and you will see the fog lamp.
The plug has to be removed before you can release the lamp. Pinch the lower part (for and aft) and pull down to release.
With the plug removed turn the lamp counter clockwise an 1/8 of a turn until it releases and can then be removed.
Install the new lamp and turn clockwise to lock in position, the cable will be at the bottom when it's locked.
View attachment 3721 View attachment 3722
Next connect the trailing socket to the original plug and I then used a cable tie to gather up the cables and tie them to the wire for the horn to stop the control unit flapping about,
Replace the cover by inserting the bottom and side then use a fist to punch the top back in.
The nearside is the same except I cable tied to the hose of the washer bottle.
Before and after comparison.
View attachment 3725 View attachment 3726
