So I scanned for codes after I got the flashing coil light and it returned the code P0183 Fuel Temp sensor A circuit high.
Found a similar post where someone had found the cable to the sensor badly frayed and mine was exactly the same.
So I repaired as best I could but it was very close to the plug, so not brilliant.
Code is still showing and coil light still flashing.
So I’m guessing the sensor itself could be fecked?
I’ll replace, but I need to replace the plug as well ideally…
Could anyone point me to the appropriate bits?
Dunc
Dunc
