Full Beam Flash Fuse
OliverL4
I’ve had a nightmare my beacon lights have stopped working after I installed my dash cam, so yesterday I stupidly decided to pull fuses and check if they have blown...
stupid me forgot to remember where I took it out from now I can’t flash my full beams. Anyone know where the fuse goes in the cabin fuse box?
If you look into the empty fuse slots you will see they only have a metal insert on one side, if you see a slot with metal inserts on both sides then there should be a fuse in it
mod you wiggle each fuse any that feel loose/have side to side movement may well be in the wrong place (as only one prong is being held by a metal insert)
thanks, I’ll give this a go later on when the temperature picks up :) just had another go but it’s too cold outside to lay on the cabin floor with the passenger door open. LOL
