Fuse Box to the left of gear stick
Hi all,
Does anyone know how to remove the fuse box out of the holder?
Also is there a buzz bar running through the slot iinside one half of fuse slot?
Mark
Long nose pliers.
And yes , bus bars one side of the fuse that supplies power the other side of the fuse is the outgoing circuit.
But note that there are multiple buzz bars that are also fed via fuses.
T6 or T6.1?
On a T6 you need to remove the plastic lower dash and there are 2 screws holding the black fuse holder in. remove these and the fuse holder comes away and you can access the back etc
I removed the whole centre lower section makes it so much easier, think you would struggle to get to the rear without
