well, . . . . .Hi @Dellmassive, great write up as usual and very useful.
Maybe I am being simple, but rather than the seatbase extender battery requiring a further connection to the vehicle alternator and connection into the Clayton's DC in, couldn't you use the seatbase as the 'main' battery, running your 12v kit off that, and have a simpler mains charger to the seatbase battery from the Clayton?
Granted, you'd limit the charge rate of the seatbase and would only want the Clayton-seatbase charger running when the Clayton is charging (from the vehicle running or EHU), but that would be a simpler extended power bank? I'm sure an ignition/EHU linked relay for switching a charger would be a piece of cake for you to mock up![]()
my main usage is 240vac when camping . . . (from the LPS)
kettle,
coffee machine,
hair dryer,
twin fridges,
disco lights and fairy lights
twinkly lights
so the clayton will be running 240v mains, that will drain the internal battery fairly quickly. . . . so i need the extra seatbase battery for the extra 240v run time.
charging the clayton off grid and keeping it running is the main priority,
charging the seatbase buffer battery is a secondary concern.
if all my main kit was 12v then i could connect a 240v charger to the LPS to charge the seat base battery, . . the LPS would still need a alternator / starter battery connection wired to the DC IN to charge it anyway.
but as you say that would save the cost of a separate DC-DC charger.
the problem with this setup is a short 240v run time.
The LPS is designed to be installed as-is, . . . but my use-case will run it flat too quickly, so i need a buffer battery.
without stating the obvious - - - - "why not just add an inverter to the seatbase + dc-dc charger that im fitting" which is what i run in the Silver van. . . . well wheres the fun in that..LOL.
