Hello,
My heated seats are not working. I checked a fuse but everything is fine.
I took it apart and now I see it is not burned out.
A quick check with an ohmmeter shows 20 ohms resistance in the driver's cushion element and 24 ohms in the backrest element.
Can anyone tell me if these are normal values or if they are faulty?
Hi, my drivers seat base element works but on the lowest setting it burns my bum after a few minutes and I have to turn it off. The back rest is not working at all. Any ideas on where to start my investigations??
2017 T6 Caravelle
Passenger works correctly.
@MarksT6
Did you get to the bottom of the fault
I would guess the upper seat pad has short circuit and the seat base pad has all the current from poth pads going in to the lower pad making it get hotter
@MarksT6
Yes, you are correct. I checked and the back rest heat pad is faulty but I can't find the correct replacement.
To add to the list of my T6 woes, I now have a failed heated driver's seat. Thanks though to @Robert, I have a fighting chance of fixing this problem.
Only curiosity I have is that my seat has not totally failed. You do get a wee bit of heat after a while but much reduced from normal.
Measuring the resistance of each pad I get 1.2Ohms for the back rest and 13.8 Ohms for the base (confirmed measured 15Ohms at the main plug since elemenrs are connected in series). Given that heated seats typically use about 50 Watts of power, I'd have expected to see a total resistance of ~3Ohms (V^2/R, 12^2/3 = 144/3 ~48W). At 15 Ohms, I'm only getting ~10W which explains why I have a cold bottom.
So, I'm guessing I need a new seat base element (7LA963555C thanks @LambethBoy). Just wondered if anyone could confirm my thoughts on resitance and let me know what the base resistance shoud be? I know I could remove my own passenger seat to measure that one but I've run out of time this week for driveway wrenching.
Plus, holy cr*p, these parts have got expensive. Seems they used to be ~£50. Now they are more like £150!
Cheers, Cuiken.
Does anyone have the part number for the heating element for the back rest for a 17 plate caravelle with half leather and half alcantara? The ones I enquire about all say they won't fit.
TPS should be able to give you the part number!?
Can someone find me the part number of the drivers side front seat, back rest cover for the black leather and alcantara. 1000029645.jpg
