Just an update for anyone changing fabric seat base only. The TPS part number is 7LA963555C
Yes, you are correct. I checked and the back rest heat pad is faulty but I can't find the correct replacement.@MarksT6
Did you get to the bottom of the fault
I would guess the upper seat pad has short circuit and the seat base pad has all the current from poth pads going in to the lower pad making it get hotter
TPS should be able to give you the part number!?Does anyone have the part number for the heating element for the back rest for a 17 plate caravelle with half leather and half alcantara? The ones I enquire about all say they won't fit.
Tried that but they won't give me the part number.TPS should be able to give you the part number!?
Some are fitted / stiched directly to the seat cover and some are glued to the foam base. I’m guessing yours will be the same as @Robert at the beginning of this thread.Tried that but they won't give me the part number.
Hello, did you have any luck getting a repair? I have the same issue on a 2016 Caravelle.Hi, great work!
I have the exact same seats in my 2016 Caravelle, the driver's heated seat went first, then the passenger a few weeks later. I checked the fuse but also aware that the single fuse controls both so was unlikely the cause.
I am unsure where to turn next, any recommendations for who I could go to for investigation? Unfortunately I don't have the tools or skills to do myself, any advice really welcome. Meanwhile, cold bum journeys are my life!
