Hi All,
New to this forum and the whole T6 thing but seriously impressed with the info on this forum, thanks.
Apologies if you've been over this a dozen times but, it seems I'm not alone in finding out that the standard headlights are crap (my series 1 Landy is better!). I think I understand the H4/H7 stuff and what's needed to change them over. From this thread several pages ago, there was a link to an item in the forum shop:
Genuine VW T6 Replacement Front Headlight Unit - H7
This doesn't seem to work anymore and I can't find them in the shop. Are they just out of stock or no longer available?
Daft question, if I change the lights over to the twin headlight H7 version, will they work normally and be OK to use before it's re-coded other than the dipped beam going off? I'm not going to be driving around with the main beam on instead of the DRL's or anything daft like that?
Force it. It won't break.
Twist anti-clockwise
Thanks - I should now be able to swap them over!
Sadly, I opened up the second of the lights and it had been damaged in transit, so looks like there is a delay to me being able to fit them...
Where did you source your lights from?Are they new or second hand?
Ian
