Does OBDeleven support TPMS activation?
OBDeleven.Cheers @Pauly , I did some VCDS stuff on my old A6 - video in motion, needle sweep etc, but someone gave me some simple instructions.
May have to look into getting hold of OBDeleven and asking for some assistance on here.
Control Units.
03-Brakes - Long Coding:
EDIT: supporting information:
---> deactivating TPMS Kombi
---> Panel van Tyre pressure monitor enable.
---> Abs Long Coding, Hill Descent Control, Tyre Pressure Monitoring
---> tyre pressure monitor system
EDIT#2: Based on the links above it seems that in the ABS need to tweak bits #4 and possibly also #5 as above. However there is a reported success having the bit#5 also the other way
The rest should be kept as they were in the van to avoid any undesired side effects.
17-Dash Board - Long Coding (this might be already set like this).
This post is won't be updated, moved to under better title for further elaboration ---> Abs Long Coding, Hill Descent Control, Tyre Pressure Monitoring
