Hard Judder then Engine Died. Timing Belt?
Hi all,
Having done a bit of research on here I think I may have a timing belt issue. I had just embarked on the return journey of a 40 minute round trip when I felt/heard quite a bit of violent judder through the steering wheel. The Engine Management bulb came on (the one that looks like a coil) and the engine died straight away so I had to coast to a stop on a very fast A road - hazards on. I tried to restart a few times and whilst it would turn over it, wouldn't fire. Eventually it did so I limped to a safe location and ran a diagnostic via Carista. I've pasted the diagnostic below so I'm hoping someone on here can interpret the read-out and chime in.
Basic OBD2:
P0087 (Pending) - Fuel Rail/System Pressure - Too Low
P0335 (Pending) - Crankshaft Position Sensor "A" Circuit
Engine:
P008700 - Fuel Rail/System Pressure - Too Low
Freeze frame :
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 255
Odometer reading: 146469.6 miles
Engine rpm: 332.25 RPM
Normed load value: 0 %
Vehicle speed: 28.6 mph
Coolant temperature: 76 °C
Intake air temperature: 24 °C
Ambient air pressure: 14.5 PSI
Voltage terminal 30: 12.093 V
P033500 - Crankshaft Position Sensor A Circuit
Freeze frame :
Priority: 2
Engine rpm: 1050.25 RPM
Vehicle speed: 32.3 mph
Intake air temperature: 22 °C
Voltage terminal 30: 12.57 V
Freeze frame :
Priority: 2
Engine rpm: 1085.75 RPM
Vehicle speed: 0 mph
Coolant temperature: 71 °C
Intake air temperature: 26 °C
Voltage terminal 30: 11.648 V
ABS:
C102DF0 - Tire pressure warning: Pressure loss
Freeze frame :
Priority: 3
Unlearning counter: 251
Odometer reading: 146452.8 miles
Infotainment system:
U101400 - Control module coded incorrectly
Freeze frame :
Priority: 4
Headlight aiming:
C103415 - Left front level control system sensor: Open circuit/short circuit to B+
Freeze frame :
Priority: 2
Malfunction frequency counter: 10
Unlearning counter: 252
Obtained with Carista 9.0 for iOS.
Download app: ‎Carista OBD2
Facebook: Carista
A little bit of history as some of this may or may not be relevant. On Wednesday last week I took it out for the first time since I had it serviced. I was very low on fuel and I had zero range left when I got to the garage. I filled up half a tank and for the first time in my ownership the DPF light came on. Now, I've had the van since August last year, only to find that at some point in its life it has possibly had the AdBlue coded out (that's a whole other story as ideally I want it reversing). Anyway, the DPF light went off eventually, but later that day I came off the bypass and slowed to about 30mph. The Engine Management bulb came on and I had a slight judder. I switched the engine off and restarted it about 30 mins later - all good as the light is no longer on and the engine is smooth, quiet and fast. It did the same thing again yesterday and then today's occurrence.
My amateur diagnosis is it's a timing belt issue so I'm not moving it from now on until I've had it looked at. I'm just looking for your input please.
Thanks,
David
As a general rule, if it were timing belt issue then it wouldn't restart. I'd also expect to see a camshaft code as top end would be out of sync.
Crank sensor looks likely, but I'm also thinking partially blocked fuel filter. The fact you had a low tank and blasted fresh diesel in, it may have thrown rubbish up from the tank base and made it's way to the filter now.
Sounds fuel related to me. Either as Kev says, or maybe a bad batch of fuel if it has just started happening after you refueled.
My T5 used to do that, and kept coming up with crankshaft sensor. I had the sensor replaced, no change. Months later it randomly stopped again, and AA got it going straight away with Easy Start, which strongly suggested fuel rather than anything else. Never did get to the bottom of it though.
When a timing belt let's go it's instant, like someone has switched off then ignition.
It'll likely be fuel related but won't be shite from the tank - plastic tanks don't rust, and in any case the fuel pickup is an inch or so from the bottom so even if the debris fairies broke into your tank and left some crud in there it won't be ingested.
Diesel has a relatively high water content (still miniscule in the grand scheme, but high compared to petrol) and fuel filter acts as a "separator' and keeps the worst of it from getting to the engine. It could be that it's faulty or needs replacement and is choking off the supply, but there are many things it could equally be so it needs some proper attention and not merely Internet guesswork and a few random blasts from the parts cannon.
Let us know how it goes. Best of luck.
Thank you all for pitching in. I'd much rather it was fuel issue than the timing belt tbh. It does seem a bit of a coincidence that this is happening just after I had it serviced.
On checking the invoice I've had a new oil filter, air filter, fuel filter and cabin filter as well as new oil and a sump plug.
The garage has offered to have it back tomorrow to check their work and they've ordered a new fuel filter in the meantime.
I'll keep you posted!
I'm hoping (for your sake) that it's an air lock in the fuel system that they created when changing the fuel filter and not bleeding it through properly.
Well it appears that I spoke too soon. It happened again last night as I was accelerating from a 30 to a 60 zone. Interestingly it’s always on the return journey so I’d say it’s only when the engine has warmed up. More hard judder, rev counter up and down and the engine management warning light flashing on the dash. I eased off the accelerator and it mainly subsided if not a little lumpy. Made the 1/4 mile journey home, engine off then back on again. It ran fine and the light had cleared. I’ve realised it only does it when I’m accelerating. Mines a DSG 4 Motion so I’m not really conscious of what gear I’m in but it’s done it once pulling away from a stop, but mainly it happens in 4th or 5th gear. It’s intermittent as well so it’s not like it happens consistently.
My van has always chucked out a bit of black smoke on start up and especially in reverse. Walking around the van after a journey it’s smells hot with a faint diesel smell so maybe I have a cracked fuel line causing a vacuum? I’ll have a good look today.
Oh yes and the fan will run for a while after it’s parked up. The oil temp never gets above 83c though.
Any help to diagnose is much appreciated or recommendations for a good VW specialist near Selby. I’d like to avoid a main dealer as the PO has coded out the adblue 🙄
I’ll need to find the receipts, but I know he had it ‘cleaned’. Is it possible to check the DPF by sight?
You could look at the dpf for cuts that have been re-welded, particularly on the top of it (which will be difficult, use a small mirror) as obviously when it's done it is done in such a way to make it hard for an MOT tester to spot!
Understood thanks. So the legitimate way to clean them is to let them regenerate. Otherwise they’re gutted and the adblue requirement coded out?
If I’d known at the time I would have passed on the purchase.
If somebody has coded out the adblue there's usually a reason for that and it usually involves a history of problems, so for me, that'd be a red flag and I'd move on to the next van.
First AA man who recovered my old van with faulty crankshaft sensor told me yes, it would cause judder, as the van thinks the crankshaft is in a different phase to the reality. It could be I really had a crankshaft sensor problem, and then later I got an air in fuel problem, which presented with the same symptoms.
Or maybe it was crankshaft sensors all along, and it started with easy start because it was getting fuel from the air intake, rather than the van commanding it based on crankshaft position?
