Hi peeps. Looking at changing my headlight bulbs but you appear to need 15 knuckles to get your fingers in so looking at removing the headlight units. Found the 2 torques screws on top but still won't come out? Is it a grille off job? Ta all
Is it to change the H4 bulbs? If so, the lights do not need to be removed to do this.
For the driver's side I just removed the top half of the air box to get access, much easier.
Remove the 2 air flow sensor plugs (they don't just pull off, there is a catch you need to release to allow them to be pulled off)
Slacken large jubilee clip
Flip up the couple of catches that attach the top half of the air box to the bottom
With a bit of jiggling, the top half of the air box will come off. DON'T force it, it is tight but will come out.
You will then get good access to the bulb cover and lamp.
For the passenger side it is fiddly but manageable as long as you use a small mirror to see how the bulb location catch comes off, but remember to remove the bulb plug first as it is tight to remove.
Hope this helps!
