Heat shield
anorak bo
T6 LWB rear deflector plate ( drivers side )
Loose …
All the small round spring discs in place
( the ones size of 10p piece )
What bolts or other fixings needed
As as they missing some
Would be good to know exactly what should be in place
I’d suggest the covers been off before and whoever put it back on didn’t line it up properly and the studs are behind the cover as there’s not much allowance for being off centre. If they are missing though your options are to weld on some new studs or drill and tap the locations and bolt on
Thanks for your reply , studs intact .
I should have made it clear regards my query.
I just want to know the bolts / screws that should be used and where
The studs are fine , and circular clip washers in place .
Wondered what else is used
Maybe someone knows how to remove it and remembers what was unscrewed etc
