Heated mirrors
I posted a VCDS code on Monday under a different thread in the VCDS area, titled heated mirrors and VCDS.
Whilst going through the modules I found one that states "heated mirrors on with rear windscreen". I am yet to actually test the electric circuitry, but I believe that this will most probably set up an 'and' gate. In that the mirror switch on the door "AND" the heated rear windscreen have to be on for the mirrors to actually heat. As the heated rear screen is relay time based, once it switches off, I expect that this will then isolate the mirror heaters (even though the mirror switch will still be on).
i have mine configured like this and it doesn't matter where you have the mirror control, if you turn on the heated rear window the mirrors come on but you can not turn the mirrors on there own with the mirror control.
I'm going to switch mine back to normal, i would rather control them separately
