Want to get my heated double seat sorted before winter. Before I order the new heatpads, which looks to come under one part number and they're on back order, what's the best way to diagnose the fault?
Driver's seat heats fine so I'm thinking the fuse is good.
I've tried using the multimeter on the resistance setting on the cabling for both pads but not sure on my results as I'm not multimeter expert. For one, it momentarily flashes up a big number then returns to '1'. For the other, the display just goes blank when on the terminals.
Any assistance much appreciated before I spend a few hundred pounds on new heat pads.
Edit: I should point out I've got a T5.1 if that makes a difference.
Thanks,
Dan
