Just tried this with help of the good lady wife, no joy.With everything turned on and lit (if you get anything at all) give the bottle a shake including turning it upside down. That may well get it going. I had a similar issue once when swapping to a new bottle.
Ah, that’s a shame. I would suggest the 8 or 10mm is the inlet pipe size not the outlet. Measure the incoming copper pipe to see what size it is and go from there.Just tried this with help of the good lady wife, no joy.
Awaiting a quote for an engineer to replace the regulator. Depends on this amount whether I attempt myself.
Presumably the 8mm or 10mm refers to the copper pipe outlet?
Incoming FROM the cylinder yes? That’s a flexible black hose type yes?Ah, that’s a shame. I would suggest the 8 or 10mm is the inlet pipe size not the outlet. Measure the incoming copper pipe to see what size it is and go from there.
8 or 10mm will be the outlet sideAh, that’s a shame. I would suggest the 8 or 10mm is the inlet pipe size not the outlet. Measure the incoming copper pipe to see what size it is and go from there.
Okay, so loosen that and then should just come out? Leave other one alone yesThe black one .
if you don't want to pull the copper pipe about to much undo the black arrow nut and remove the regulator, rather than remove the pipe from the regulator, remove the regulator from the pipe hopefully that makes senseOkay, so loosen that and then should just come out? Leave other one alone yes
Can’t seem to shift the yellow, so yes, will remove the black, to try and gauge whether copper pope is 8 or 10mmif you don't want to pull the copper pipe about to much undo the black arrow nut and remove the regulator, rather than remove the pipe from the regulator, remove the regulator from the pipe hopefully that makes sense
Excellent! Thank youView attachment 265682a new regulator will come with the bit you can't remove already factory fitted View attachment 265682
Yes, absolutely. Dooh!8 or 10mm will be the outlet side
Hi all,
Took
Old regulator off (on right).
New regulator has a diff connector piece?!
Have I ordered the wrong one.
Note from copper pipe, the locking collar won’t come off, do I just man handle off or should that just slide off? As stands I can’t seem to get that collar shifted?
