Bargy62 nutter VIP Member T6 Legend 20 Nov 2024 #42 Chris1983 said: Do I just pull it? Click to expand... or wiggle
C Chris1983 Senior Member VIP Member T6 Legend 20 Nov 2024 #43 You are all heroes! Worked a treat! Left all gas off after test until I can check for leaks. As always many many thanks!
Bargy62 nutter VIP Member T6 Legend 20 Nov 2024 #44 Chris1983 said: You are all heroes! Worked a treat! Left all gas off after test until I can check for leaks. As always many many thanks! Click to expand... Out of curiosity did you get the quote to change the regulator if so how much did they want to charge.
C Chris1983 Senior Member VIP Member T6 Legend 20 Nov 2024 #45 Bargy62 said: Out of curiosity did you get the quote to change the regulator if so how much did they want to charge. Click to expand... Guy I emailed (caravan and camper gas engineer) never replied. I do wonder if I am expected to get a certificate or hab check etc? Or is that all just extra reassurances? I will of course be reassured if no leaks detected
C Chris1983 Senior Member VIP Member T6 Legend 20 Nov 2024 #47 I don’t rent out, so that is useful to know, thank you
