Hi @Texxaco If you mean the ones in fusebox SA - no not yet. Job for tomorrow nowHave you checked the main fuse near the battery?
Yes will doWhen you get in there, could you take some photos please. There don’t seem to be many (any ?) on the forum.
Pete
I once had a similar situation on my T5 where the battery earth lead had frayed at the connector and there were only a few strands connected. I found this out the same as you by knocking against something.This is going to be interesting ands frustrating - just went out and plugged the mains in to charge the leisure battery. As I was fumbling around in the dark on the left hand side of the engine bay by the battery I saw the headlights flash!
So I finished connecting the mains and then pressed the unlock button of the key fob and ...... the van unlocked. I locked it remotely and then unlocked it remotely. The interior lights worked when I open the drivers door. The instrument panel lit up when I put the key in and turned on the ignition. Fantastic - Then....
I turned the ignition key to crank the engine and everything went off again - no lights, no remote locking no instruments, no interior lights?
Very puzzling - poor or loose connection somewhere?
There is a main fuse near the battery, I am not sure but that may be the cause?Hi @Texxaco If you mean the ones in fusebox SA - no not yet. Job for tomorrow now
The main fuse is fusebox SA and heres what they look like
Thats really helpful @Pauly thanksI just posted a little guide in the VIP section that may be handy for you if you have never accessed the ebox before, just covers battery removal and lists all the fuse functions
