Based on the blockmap data we actually might have more issues - interestingly not manifested themselves as fault codes - yet.
1) Wiring problem by barometric pressure sensor (G71)
because we get this
IDE07735 Air filter outlet: pressure sensor 1 bank 1: uncnd. voltage 4.999 V
Some related experiments and explanations here
Can anyone shed any light please on this error code P011100 Air intake temperature sensor1? (2017 2.0 CXGB) I have reset the management light and it stays off for 3-5 days then its back on again. When the eml is on it still drives absolutely fine with no noticeable difference at all. I have...
www.t6forum.com
Then the next in the queue...
2) Wiring problem by Exhaust temperature sensor 1 - before turbo charger
Plain wrong - reads out at max negative which suggests open circuit
Interestingly this didn't manifest itself yet but will probably interfere/inhibit DPF regeneration - which has been already initiated.
3) Possibly clogged manifold pressure sensor (G31)
Captured in fault code freeze frame
In blockmap data
Should be close to ambient pressure - especially when engine off.
More details
Hi, I'm having an issue with my van, the EML is on and glow plug light is flashing and i have 2 faults. I removed the boost pressure sensor and it was clogged with soot, I cleaned it but that didn't have any effect so I have one coming on tuesday, but the 2nd fault with the "open circuit message...
www.t6forum.com
I've started to wonder if the fault "Sensor reference voltage" is actually a consequence of the open circuits...
