Hi all,
Looking to add 230v hookup to my existing setup. This is mainly just for battery charging and maintenance rather than for running 230v appliances.
I've created some wiring diagrams of the current system and how I think it will need to look post install. I'm not the best at understanding electrics so I'm sure the diagrams I've put together aren't 100% accurate but I've tried my best. I know there grounds probably aren't right for starters. I didn't install all of the electrics in the van so I'm making some assumptions as I can't easily access the current system without removing the seats and furniture etc.
However.....I'm thinking of getting the Victron IP22 Blue Smart 12/20 3-output charger so I can connect it to both my starter and leisure batteries. I know I need to get a 2 pole RCD and breakers. Planning on putting the charger on one circuit and then having some spare 3-pins on another circuit.
Do the diagrams look right and is there a better way of doing this?
Current system
Proposed design
Any advice....or criticism welcome.
Cheers all.
Current system
Proposed design
Cheers all.
