how do you find the ride height does it catch in any car parks or anything? I've just brought a T6 with coilovers and unsure how low to take it![]()
No it's all fine with parking nose up to standard height curbs etc.
Thats great thanks, will drop it down moreNo it's all fine with parking nose up to standard height curbs etc.
That’s at ride height.You call that low?
Hello Simon, give the office a call. They will put you through to someone that can advise you. 0116 2478156
@Solow Suspension Surely a response here would be beneficial to all members thinking the same?After thinking about it for about 10 years, I've finally done it and bought a 2018 T6. It arrives on Friday. I will do as much of the conversion as I can myself, but the pop top roof is beyond me. Does anyone have a suggestion of where I can go to have this done? I live in Surrey, but will drive as far as I need to if the price is right and it is someone recommended.
Thank you in advance for any help and advice as this is daunting for a novice.
David
I'm dyslexic and a very slow typer. There are also lots of other questions to ask to qualify what would be the best set up. I'll talk for hours on the phone and offer advice though.@Solow Suspension Surely a response here would be beneficial to all members thinking the same?
Looks stunningView attachment 256120
Been on solows for 2 years and can’t fault them. Just got solow air management and away to get bags sorted.
Hi which solows were fitted the low or nsl?Finally managed to give the van a quick wash after having the Solow Coilovers fitted by @supremeconversions on Monday last week.
Have to say the lads @supremeconversions in Telford have done an amazing job.
These Solow Coilovers have absolutely transformed the van in every sense. The ride is sooooo smooth, not more steering wheel snapping from side to side when I hit a minor bump. It’s a pleasure to drive. I wasn’t sure what height to drop to so took advise from the lads. There is plenty more these can be lowered by apparently.
Heading back in a couple of weeks to have Hunter 4 wheel alignment done.
Low.Hi which solows were fitted the low or nsl?
About time tooLow.
I keep looking at it thinking I might head back and get them to drop it a little more on the back. There lots left apparently.
@Solow Suspension
Hi Andy, I've had the SoLow NST setup on my work van for about 2 months now. Love the way it handles and looks now, especially with the new wheels.
I believe its down about 80mm... wheel centre to arch is around 385mm with my usual load of tools and stuff.
I had the alignment checked this week after finally sorting the wheels with the proper hub rings. See picture.
Toe in on right rear is off the charts from my understanding... and there was no adjustment left apparently.
So I'm guessing I should get some adjustable bushes, but it looks like even that wont be enough.
What do all the slammed guys do? Do they just put up with bad alignment and therefore bad tyre wear?
I dont really want to raise it much as it looks so much better and I can get into the smaller carparks now.
I appreciate your thoughts
They are original, I just cut them down with a pair of tin snips! After fitting the NSL's the flaps were scraping everywhereWhat brand our your mud flaps please? They look OEM location wise but no where near as long.
So you have any close up images, this sounds something I need to do as mine scrape quite a lot too.They are original, I just cut them down with a pair of tin snips! After fitting the NSL's the flaps were scraping everywhere
