Stealth Elevating Roofs | Low Profile Pop Top Roof Conversion | Bus & Van Life
The Stealth low profile pop top roofs are easy to operate and designed specifically for Volkswagen Transporter and Ford Transit Custom owners. Get your quote to
There were a ton of fitting issues with low-life too, right? Not heard much recently tho.Stealth Elevating Roofs | Low Profile Pop Top Roof Conversion | Bus & Van Life
The Stealth low profile pop top roofs are easy to operate and designed specifically for Volkswagen Transporter and Ford Transit Custom owners. Get your quote tothestealthroof.co.uk
Thanks for the Replies, looks like XtremeVan it then if i decide to go this route. Id still be interested to hear about any other Low Profile roofs if there any out there.
Didnt hear about those. They have a new roof came out this Feb though.There were a ton of fitting issues with low-life too, right? Not heard much recently tho.
To be fair, when I researched the HILO roof system there were very few negative comments on any forums, and plenty of positive ones. I think the balance has tipped the other way over the past 12 months - no denying that some folk have got a good roof and used a quality fitter, but as I said previously it's about assessing the risk - things change over time too - great to hear a 2017 roof working well, and a good experience from 2019.
I've spent over £40k (and lots of hours doing element of the conversion) to get a low profile roof camper, but the pop-top doesn't function as advertised. Not a fitter problem, a manufacturing one. Sorry, manufacturing problems (multiple). And botched 'repairs' by HILO themselves.
What do you think the resale value is likely to be for my T6 with a HILO surf roof?
Do I want anyone else to find themselves in this position?
Does anyone else deserve the mental health impact of going through this for 12 months?
I think not.
So please forgive me for being negative - it's not without good reason.
People are of course at liberty to ignore others' experiences, good or bad.
Value wise the more criticism and negative discussion there is about a product the more difficult it will be to sell. It’s a hard line though as companies shouldn’t be allowed to get away with poor service so can understand naming and shaming.
Are you going to change the roof to another brand?
I wish you luck and hope your experience hasn’t put you off the T6 life. I can’t imagine being without one now.
So camera not working because the wiring had been damaged by a bolt, and the van wouldn’t start because of a fuse of the same rating as the reversing camera having been stuck in the wrong hole. I passed this engineers report onto HiLo.
This was Matt Adam’s response.
Date: 24 September 2019 at 11:02:13 BST
To: @btinternet.com
Dear Mr B
Thank you for your mail dated the 18th regarding the issues with your Vehicle uncovered at HiLo whilst work was being undertaken to rectify fitting issues you had from your HiLo roof installer.
Thank you for submitting your opinion on liability, however the pictures clearly show an additional hole has been drilled in the frame and an M8 threaded bolt has been used (as you have stated). This has been done when the bed was fitted (by your installer). This hole is not on our engineering drawings which are under patent, nor do we use M8 bolts which is shown on our bill of materials. Furthermore, at no point did the work undertaken at HiLo involve drilling holes in the frame.
The work undertaken by the HiLo team must have allowed the wire to come away from bolt shown in the picture. We did ask for an independent engineer’s report, not a £900 bill from a firm known well to yourself, who undertook untold & undated works to your van prior to it arriving with us, (after installer refused to work with the state of electrics). As the issues with your vehicle were not manufacturing issues then we have no liability for the £900 bill you are submitting.
Removal of the internal covers (which is what the team did again to check for any obvious issues or lose connection) and check power was in fact going to your rear camera whilst you were off site must have led to the additional shorting failures. The only persons actually observed by multiple members of Hilo staff changing fuses or moving fuses was yourself and the Green Flag engineer. If the fuse SC31 had been in the wrong position on your return to the site, the instrument panel cluster would not have illuminated as it did multiple times and the vehicle would not have started multiple times and cut out. Therefore, additional costs incurred are as a result of aftermarket work previously condemned and not us.
We have honoured the agreement and paid travel expenses, as that was what was agreed by Lee (after our hire car was double-booked). This was based on the proviso of not knowing whether the initial issues you had with your canvass was a fitter or product fault. As you are aware the fault was not with your canvass manufacture but as a gesture of goodwill we have not asked for return of payment of travel expenses. If you continue to request payment of funds HiLo are not liable for we will invoice you at our charge out rate of £46.73 per hour for the week your vehicle was in the workshop.
Kindest Regards
Matt Adams
Operations Manager
The HiLo Roof Company Ltd
So lets just address a couple of things.
-They have obviously spoken with Dean Withers at Van Doc Ltd – or should I say VanDoc Conversions Ltd. The statement about them refusing to do my install due to dangerous leisure electrics is a total fallacy.
-When I left the van (and the site) after finding the problem with the camera it was located in the middle of the car park, and the engine was not running. When I returned it was back in the unit. At no time have they suggested they had to push it in there due to it not starting. It couldn’t have been the Green Flag Technician as he hadn’t even been called by this point!
-Matt Adams claim about what the van would and wouldn’t do with the fuse in the wrong slot. I invite every single one of you to go to your van, remove the SC32 7.5A fuse and try to start your van. I guarantee that you’ll get an illuminated MFD, but no ignition lights in your dials when you turn the ignition key. Turn the key to start the engine, it’ll fire, run for a second and die, then won’t restart. The electric windows will also not work.
-Matt now claims that I had been told to submit an “independent engineers report”. This is not what I have in an email from HiLo, which asks for an “engineers report”.
-HiLo’s threat about charging me for non-warranty work that the installer should have done. Well let’s remember (as per other thread Van Doc Ltd - - - - Vandoc Conversions Ltd) that Van Doc Ltd who installed the roof no longer exist, therefore I have no legal recourse with them. Under contract law, the remaining warranty reverts to the manufacturer due to them operating a network of approved and accredited fitters of their product, and from whose website I selected Van Doc Ltd as the HiLo installer closest to me. So the HiLo Roof Company Ltd are liable for the work that needed to be undertaken.
-They are clearly stating that Van Doc Ltd did not install my roof as per manufacturers instructions and even used parts that they shouldn’t. Clearly this is a bigger issue across their network of fitters because in the post made by @Gaz1971 in the other HiLo thread(Hilo Roofs), he has a picture of an M8 bolt protruding through the frame of his HiLo as well. I wonder if anyone else has the same?
Due to the costs associated with attending Court, plus all of the time associated (which I just don’t have) I simply don’t have the energy to issue a Court Summons and hire a lawyer. My van now works, there doesn’t seem to be the creaks that I was plagued with previously, although I haven’t put it up in the rain yet, and to be honest am petrified of doing so.
Thank you all for taking the time to read this post, I know it has been a long one, but I hope you’ve had a good look at all of the information posted that is based upon . I just hope none of you ever have to go through what I have. I honestly had nightmares about my van being a write off when I couldn’t get anyone to work on it.
I guess I will never get to the bottom of how my wiring got damaged, nor who actually disabled my ignition circuitry - perhaps it was me all along, and i’ve made everything up. However I do know this much, I will never ever have a poptop roof installed in any future vehicle I own. I loved my van, but thanks to all of this the shine has gone. Irrelevant of what led to all of this, and completely parking the fateful visit to Preston, as an owner of a HiLo Sport - I hate it. It has been nothing but a problem from the first day I picked it up after it was installed. It is for this reason, and this reason alone why I would not recommend this particular product to anyone.
