Hi, this is a bit off topic, but long story short...
I've just bought a Carista to see what version software I have in regards to the adblue fault detailed on other threads and whether I needed a software update. This stems from fault code logged by my local garage ages ago which I now understand was non active and so ignored by VW when I've asked them to check on 2 occasions.
So this is what I've got as a print out.
DETAILED ECU INFO
ECU info obtained with Carista 610099 for iOS:
VIN: WV1ZZZ7HZJH135133
Engine
Part #: 04L906056KL
Component: R4 2.0l TDI
Software version: 3802
ASAM/ODX identifier: EV_ECM20TDI03004L906056KL
Coding: 00194014432401090000 (hex)
[No fault codes]
Part number or software version don't seem to match what I've read previous on threads on this which is 04L906056KA from 4047 (old) to 6163 (new)
Slightly off topic. Have you got any notes about 04L 906 056 KH (H02 3805) ? Just curious, I am not looking for anything special/specific. Yes, indeed - has gone through three versions. 04L 906 056 KH H02 3805 04L 906 056 KH H02 5952 04L 906 056 KH H02 6184 = the current
www.t6forum.com
so i googled it and it came up with this thread instead, which matches my read out except its running the factory software 3802, and then you mention about having had an update for the adblue and are now running software version 6166
''Engine software 04L 906 056 KL has two versions in VW inventory.
FL_04L906056KL_
3802__V001.frf
FL_04L906056KL_
6166__V001.frf ''
So can someone (mmi?) please just confirm that I am not going mad and my van is running old software which I need to get updated so I can pursue this when the van goes into VW tomorrow.
