im not certain, but i think thats the grey wire he has added himself..... i cant see a grey wire on the T17f connector in the schematic.It looks grey with a black stripe on my screen, but I can’t be certain.
some more clearer pics please @R4Sty
.Thank you, I'm reading your updated thread about it,
Is it hard to pass a wire from fuse box to under seat?
Ditto, I fed through some arctic flex today and managed to do that without removing the carpet - I lifted it at the back end, popped the tunnel off its front mount and reached through and grabbed the cable.I've managed to fish 2 thick speaker cables, 2 double phono leads complete with plugs and 2 other wires through that tunnel without removing the carpet so one will be a piece of cake. Either use fibreglass electricians rods or fish tape, if you don't have either then they're only cheap and after a while you won't be able to imagine life without them
10x 330mm Cable Access Kit Wire Rods Electricians Floorboards DIY Carpet Hook 791429429861 | eBay
DTN10 - Flexible Draw Tape Electrician Fish Tape Nylon Cable Puller - 10m Length | eBay
Any idea what wire is the BCM feed under passenger seat? I have a Caravelle so hopefully there's one. I need an engine on feed to power a relay that I want to use so my inverter only functions with engine running so this sounds ideal.While not an ignition feed as such,
you can use the BCM feed as a switched 12v feed which is live when the "engine is running".(just be sensible and dont try a draw 50 amps from it) (we used the BCM feed to switch our REDARC but also KEPT the AUX relay and used that as a switch to shunt the load from the AUX battery for any circuits that needed ignition or engine running only feeds, via a new fuse box)
It will only be present if you have the factory fitted Aux battery optionAny idea what wire is the BCM feed under passenger seat? I have a Caravelle so hopefully there's one. I need an engine on feed to power a relay that I want to use so my inverter only functions with engine running so this sounds ideal.
Ahh OK. I might just use a TEC3M to avoid flattening battery. ThanksIt will only be present if you have the factory fitted Aux battery option
It's fairly simple to put the signal cable in yourselfAhh OK. I might just use a TEC3M to avoid flattening battery. Thanks
Thanks but given the option of working under passenger seat or getting my fat fingers up to the BCM I choose the former. Had I had forward thinking I could have done it on either of the two occasions of towbar fitting and cruise control retrofit however I'm old and fat and struggle getting access to the BCM wiring.It's fairly simple to put the signal cable in yourself
T6.1 Ignition Live for DC-DC B2B Charger
Does anyone know where I can get this? Is it the same as the T6?www.t6forum.com
Simple for you @DeakyIt's fairly simple to put the signal cable in yourself
I'm good thanks mate.Simple for you @Deaky
Hope you're well pal
I know this is an old post, but as you have tow bar this might just work:-Does anyone know if there is an “Ignition Live” or a “Engine Running Live” under the passenger seat or drivers seat of my VW T6 Kombi Twin Slider with Tow Bar? I’d rather not pick up from under dash fuse box, if there is one here available. TIA
