Only asked as I noticed the same issue today! Mine has mysteriously stopped… same issue couldn’t quite pinpoint where it was coming from- I have a leisure battery charger and also alarm/immobiliser could have been either!Thank you for the chaser on updating this fault. It was a silly one! It was the leisure battery charger which is mounted under the driver's seat giving an over voltage alarm! I have not got to the bottom of why it is going over voltage yet, but the solution is to turn on the lights or something and then it goes away. So nothing to do with the poor old van at all. The problem is with these high pitched alarms you can't tell where they are coming from.
