Jacking Points And Axle Stands
surf-report
Gas Engineer
Can anyone tell me what points they jack their van up with when using a trolley jack please?
Found this pic on net.. Essentially anywhere a two post ramp lifts this is front
Found this one, might be worth making a wooden block up as an alternative..
Wouldn't think polymorph would be strong enough to.. Mind you could then use it to get a metal one made...
Or mould some polymorph..
And there was me thinking that Polymorph was an episode from Red Dwarf Series 3 (episode 3 to be precise). Had never heard of it in any other manner. It's true, everyday really is a school day.
I had to put a wooden fence post between the van and my jack when I changed my wheels over as the trolley jack I have doesn't lift far enough off the ground
Morning All,
Maybe a silly question, but were is the best place to position a trolley jack? I've looked underneath and the original jacking points don't look safe to use to me and I'm paranoid I'll bend the metal.
I use the original jacking points with my super low 3 ton trolley jack but it does have a large plate and a rubber pad attachment. Seems super stable and the metal does not bend.
At the rear you should see a right angle of chassis sticking down in front of the rear wheel where the rear wishbone swivels.
At the front I use the wishbone or the jacking point with pad, depending on what I'm doing but use stands if I'm going under...
I use the trolley jack under the normal jacking points with a pad. If using stands, where do you put them under the van once the van is jacked up on the trolley jack.
When you say Pad...where can I get one and do they need to be specific to my jack?
Can be many things, softwood, a Hockey Puck, custom moulded Polymorph are all the things I have used in the past.
Here are a couple of my custom ones.
