I have space to 'park' a mobile scissor sideways behind the van so I wouldnt have to park on it all the time.Oh wow, very nice!
I don’t have room for a 2 post, so didn’t have much choice. If I had yours I’d consider setting a scissor into the floor and having covers! A car lives on top of mine most of the time, so doesn’t cost me any space which is nice.
I love how OT we are now.. sorry OP!
So just a thought, what’s bad about using a trolley Jack under a rear jacking point with a rubber connection, lifting the van and putting a wooden sleeper cut down under the wheel, lowering the van onto that sleeper, then replacing the trolley hack with an axle stand and doing the same on the other side at the rear. Leaving the axle stands and sleepers there as backup?The challenge is, as someone said on another thread, with only 4 official jacking points the only truly approved way to lift the van is with a four point lift on those jacking points. Beyond that people are likely nervous of becoming the "definitive answer" in case the worst happens when people follow their suggestion.
The official jacking points are the 4 angle iron pieces highlighted in the first post of this thread. You will need to use a jacking pad to protect it on a normal jack as it's designed mostly for the "hook" of a scissor jack.
The problem is with a single point jack on the jacking point there is no where to put an axle stand, and it is unsafe to work under a van with only a single thing stopping it falling on you. The best you can do is to take the weight on the jack on the jacking point and put an axle stand as DXX suggests on the body lower wishbone mount. On the rear the challenge is the anti roll bar, which is in the way and not strong enough to use instead. Someone else has posted a picture of a bottle jack and a stand arranged very close together on a large block on the jack point. You need to decide if that is safe enough for you considering the place you have to work on your van and the tools you have.
If you are not comfortable with the safety of that there are places you can hire servicing bays with a four point lift such as:
Workshop : This is Your Garage
thisisyourgarage.com
I guess the issue would be if you need to remove the wheel(s), then this approach wouldn't really help. ¯\_(ツ)_/¯So just a thought, what’s bad about using a trolley Jack under a rear jacking point with a rubber connection, lifting the van and putting a wooden sleeper cut down under the wheel, lowering the van onto that sleeper, then replacing the trolley hack with an axle stand and doing the same on the other side at the rear. Leaving the axle stands and sleepers there as backup?
I need to install water tanks, lpg tank and lpg heater.
good idea then vehicle is only resting on the wheels which as @roadtripper highlights it does all day long.So just a thought, what’s bad about using a trolley Jack under a rear jacking point with a rubber connection, lifting the van and putting a wooden sleeper cut down under the wheel, lowering the van onto that sleeper, then replacing the trolley hack with an axle stand and doing the same on the other side at the rear. Leaving the axle stands and sleepers there as backup?
Quick question @roadtripper: would you be happy to work under a van that was just sat on appropriately-rated ramps (on the assumption that afforded enough room for the job at hand) or would you still look to use axle stands in addition to the ramps?Also if you don't need to take the weight off the wheels consider ramps as well, then you don't put any load on anything that isn't taking load every day.
Has anyone used ramps like these to get extra lift?
Looking to some work on underslung water tank and what to make access as easy as possible.
Hydraulic Car Lifting Ramps 3 Tonne
Elevate your garage's capabilities with these heavy-duty hydraulic car ramps, the essential tool for any mechanic, ensuring effortless vehicle maintenance. This set includes two sturdy steel ramps, with an impressive combined weight capacity of 3-tonnes. These car ramps each feature a manually...www.diy.com
I use something similar to that. There is an abundance of poorly manufactured lifting gear, especially ramps on the market.I wish I had a set of those this morning!!
These "ramps" have been handed down to me from the father in law
Yes @DXX they are solid pieces of timber, that's for sure.I use something similar to that. There is an abundance of poorly manufactured lifting gear, especially ramps on the market.
IMO you are better off with something solid in this situation.
HmmLong in depth thread here:
Jacking points, trolley jacks and axle stands
I’ve lifted cars on trolley jacks at home before, and I’ve been very happy doing so as it’s been obvious where the jacking points are, and cars aren’t that heavy. But before I set about getting my van up in the air, I’d like to ask the knowledgeable folk on here how they go about this. I’ve...www.t6forum.com
